I have been using Elements 4 for a few years & saving a slide show either to memory stick or cd. I recently tried inserting a memory stick with a slide show on it into an HD projector rather than a straight data projector. The images appeared over exposed & far from right. What is the difference using an HD projector?? If an HD projector is to be used, how should I make the slide shows so that they can be reproduced accurately?? Is it all in the sizing of the images?? Thank you for assisting me with this recent problem. Lois Thompson -- jayell@westnet.com.au.
    Sergeant:
    Champion:
  • 258 Answers
I think hd projectors still have problem when it comes to compatibility so i advice you to read the manuals of the hd it could be size or the format of the slide show
Posted on Feb 10, 2009
How do I transfer my bought Photo stage slideshow to another computer
take the slide show in the pen drive/memory stick and copy the slide show in the same. and then insert the same memory stick or pen drive in the computer you want to transfer and then once the pen drive opens in the other computer paste all the slide show content in that one.
Aug 21, 2013 | nch.com.au
My samsung dvdc370 does not read movies from my usb
Are the movies inthe correct format for the player? If it does not register the USB drive, try it without a cable if one is used, and make sure contacts are clean. if it still does not register, the port cotroller may be dead.
Jan 24, 2012 | Samsung DVD-VR357
My dsc-w80 keeps saving all of my pics to the internal memory
Set camera on playback mode, you will see any saved picture in internal memory. Insert memory card and lcd screen will show you either blue screen if memory card has no picture files or will show you picture in memory card. That means memory card is intact with camera and ready to store fresh picture.
Set camera to camera mode and take few fresh pictures and check them in playback mode.
Let me know if you have additional question.
Thanks.
Jul 20, 2010 | Sony Cyber-shot DSC-W80 Digital Camera
How to use a memory stick right from the start
hi
  • Understand how a Memory Stick Pro works. The small card saves information from a portable device. You can save, delete and rewrite to the card as many times as you want. You can also remove the card and insert it into another device. For example, you can save photos from a camera, then insert the memory card into your laptop to view or download the images.
  • Step 2 Make sure you buy a memory card that matches the demands of your electronic device. The cards have different saving speeds and data-holding capacities. Generally speaking, the more data the card can hold and the faster its speed, the more expensive the memory card. Check your electronic device's product information for recommendations on the best type and size of memory card.
  • Step 3 Insert the Memory Stick Pro into the electronic device. Most devices have a small flap or cover on its side that holds the card. The memory card slides into a slot under the flap. Gently push in the card and close the flap.
  • Step 4 Save to the memory card. Once the card is installed, many devices know to save new data to the card. In some cases, however, you may need to specify where to save files, either to a built-in hard drive or to the memory card.
  • Step 5 To remove the card, open the flap and gently press the card in. The card should then pop out of the slot for easy removal. The card can now be inserted into another device.
  • vote me if your setisfied
    Jun 29, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
    Memory stick format
    Hello Sir
    #1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    # 2 Open up 'My Computer'. You should see it under the list of available drives.
    # 3 Check its contents first to make sure that you have the right drive.
    # 4 In 'My Computer', right-click on the drive and choose 'Format'.
    # 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    # 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    Dec 25, 2009 | Coby Electronics DP-812 Digital Photo...
    I have pictures on the card that show up on my
    Keep the memory card in your camera....plug your camera into the computer and then turn your camera on...options should start to appear on the screen...follow the questions to get your solution...
    Nov 08, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
    Unable to save in the memory stick
    the memory card automatically locks wen u insert in the phone...
    go to moto service centre
    Jul 07, 2009 | Motorola Mobility ROKR E6 Smartphone
    Will not save to memory card
    First, check to make sure the memory stick is not locked. There is a little switch on some of the cards that will protect the images stored on it, but will also keep you from saving any more. If that is not the case, then try deleting all the images from the memory stick using your computer. Then, format the memory stick using your camera, and try to use it again. Hope this helps!
    Mar 13, 2009 | Cameras
    Dsc-s700 format error
    If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
    Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
    "No Memory Stick" error (but I never had one!)
    W don't you just get a memory stick for it? Then you don't have to "write off your $300 camera as a total loss"
    Dec 25, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
    Computers & Internet Logo
    53 people viewed this question
    David Payne
    David Payne
