Question about Mitsubishi VS-55707 TV
Screen Jumpy on various Inputs
All inputs but the main cable input are jumpy. Sound is fine but video bounces really bad.
  • 42 Answers
This unit had a very bad problem with the pip bord
Several caps have to be replaced on the board
I would have a tv repair shop do it for you
You have to remove surface mount caps and replace them which is hard to do
Posted on Feb 10, 2009
  • tom woodward
    tom woodward Feb 10, 2009
I have a samsung ln40d630m3f sound but no picture. Any ideas?
HDMI or? Depending on what input your using i would say check and even swap the cables. I had a few come through for repair that ended up just being bad HDMI cables that were passing audio but not video.
If thats not it, and none of the inputs work, also try going to the antenna or cable input if your not using those even if nothing is connected to the coaxial input just to see if you can get snow or a blue screen saying no signal, then i would suspect you have another failure inside. Could be a power supply issue but that generally affects video and sound, could be a bad backlight inverter, the picture is actually there but you can't see it. Try a really bright flashlight, get up close and shine it on the screen at an angle and see if you can see a picture there thats just really dark. Sometimes the backlight inverter fails and the tv is working fine otherwise.
Nov 25, 2015 | Samsung Televison & Video
Ghost images
Is this a projection? If so the internal components could have issues and I wouldn't recommend trying to repair that. If it is a LCD or Plasma if may be an issue with that specific input or cable. Try another input like the antenna or cable input and see if it has the same issue. If it does the issue is again internal. If not than the one input may be the issue. Try replacing the cable or changing the device on the bad input. It that works great if not, you may not be able to use the one input. Also try and unplug the TV for an hour and try again. Good luck!
Apr 09, 2014 | Televison & Video
I have 60inch plasma tv. the power is on an the blue light,but no sound an no menu or picture.can you help me pls?
Please cycle the unit through the various inputs to make sure it is on one with something hooked up to it.
Either that or a defective cable someplace--double check the hookup and start with just a DVD or something connected to a single input to see for yourself if any input is working.
The inputs are of course different from the cable fitting and it is possible for the tuner in the set not to work but the rear audio/video inputs to work.
Let me know what you find.
Mar 14, 2012 | NEC Televison & Video
I have a apex 32-inch tv model (AT3208S), This tv was connect to a converter box, the other day electric power went out in our area for about 8 mins or less, once the power was back on the tv screen was...
OK, I have one of these TVs, and here's a thought: There's nothing wrong with the TV nor with the cable converter box. Please bear with me. Since I don't know how much you may know about TVs in general and this one in particular, I'm going to assume you know nothing and go from there.
This TV has several different "inputs", which are ways a signal can be transferred from its source to the TV, where it "outputs" the video image. I believe this particular TV has 5 different inputs: In descending order of the quality of the video signal, there're one S-video input (a 4-pin video connector plus red & white audio), three composite video inputs (3 connectors each: yellow video and red/white audio--audio connectors are the same for both s-video and composite), and one coax connector (a single large screw-on connector with a little wire sticking up through the center of it) for a total of five different inputs.
The problem with these Apex TVs is that they always default to the Antenna/coax input first when they are restarted. Most people use the TV to display an input signal (like the cable box or a DVD player) connected either to the S-video or to one of the 3 composite video inputs, not to the coax input, which just displays the channel numbers from 1-125 when it's set to do that (hit the "display" button on your remote to toggle showing the channel numbers for the coax input). If there's no signal coming into the coax input, the screen with appear blue. (If it's blue, it simply means it's not getting a signal via the input to which the TV is currently set. You can turn off the blue screen in the menu settings, but then you'll just get a blank screen. It's probably better just to leave the screen blue; at least you can tell the TV's actually trying to display something that way.)
You have to manually select the proper input by pressing the "video" button either on the remote (lower right corner) or the "video" button directly on the TV (hidden control panel under the middle of the margin around the bottom of the TV screen. You'll have to press on the door, and the whole control panel rolls open to reveal another set of composite inputs and some buttons. The video button is the one farthest to the left.)
Anyhow, by pressing the video buttons, you'll cycle through the various inputs. Assuming your cable converter box is functioning properly, powered on, receiving a signal from the cable company, and connected to the TV via a(n) appropriate wire(s) connected correctly, you should see the output from the cable box on the screen when you cycle through to display the proper video input.
Another possibility: the power outage fried the input to which your cable box was connected on the back of the TV. If that's the case, your cable box would probably also have sustained damage. You can check to see if the various video inputs on the TV are working by connecting different source inputs (like a BluRay/DVD/VCR player, video game console, video camera, etc.) to one of the other inputs and see if you get a picture when the TV is set to the appropriate inputs. (Remember, the "video" button is what selects/changes/cycles through the various video inputs.) One of the sets of inputs went bad on my TV. I just use the other ones.
May 18, 2011 | Televison & Video
What setup should I be in to successfully watch over S-Video. I get wavy and jumpy and white-out reception.
Assuming you have S Video inputs on your TV and S Video output on your Video Source, there is no connection easier to install. Either use the 4pin MiniDin lead or phono plugs for composite video.
Jan 01, 2011 | JVC Televison & Video
Bad color on input, fine on test pattern
If you know your source signal is good, try changing your input cable. If the problem still exists there may be a problem with the signal input board. Try various inputs VGA, composite video if you can
Aug 10, 2010 | Panasonic PTD9610U Multimedia Projector
Poor viewing with VCR
how do you have the combo connection and dish network hooked to the tv ? if you have an s-video , yellow RCA jack video or component video hooked to the same input then it will act this way, because two inputs cannot be on the same video input # on the tv.
is this what is happening? or how are you connecting it?
Jan 04, 2009 | Samsung DVD-V4600 DVD Player/VCR
Problem with the video inputs....
Your problem is the MICOM board. It is a standup board the plugs into the main board. It is basically the "brains" of the tv. It does all of your video processing,video switching, etc. It is also a very expensive board (around $400).
Nov 30, 2008 | JVC AV-48WP30 48" Rear Projection...
HDMI Audio from receiver to TV cuts out?
Try to power cycle your unit (unplug it from the power outlet for about 5 sec) and try to swap your cables and inputs. After doing that if the problem is still there reset the unit back to it's default by pressing and holding the VCR/DVR button and tap the stand by button at the same time that's resetting the unit but just to remind you it is going to erase all the settings of your receiver therefore you have to reassign the inputs again. After these procedures if problem still there you need to have the unit looked at. Hope this one helps you.
Nov 18, 2008 | Onkyo TX-SR605 Receiver
Inputs
learn lip reading..... but really 1080i inputs have to cut main circuit and be processed through your main amplifier .
shorted or too low a signal at input is a start.
Jan 08, 2008 | Samsung DLP HL-P5663W 56" TV
Mitsubishi VS-55707 TV Logo
126 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
