I have just had my cable provider - Shaw install their new Gateway system and now my remote will not work It will turn on the tv but not change channels or change the volume Another question re my LCD TV AT3705-DTV - I guess I need a code for it too as the new remote won't work
SOURCE: digital tv
Hi Here is a link to an englis version of the manuals right click on the left one on this page and do a Save as, it will take some time to load as this link goes to taiwan :( file is about 4.5mb, I have checked this and it does appear ok, good luck :)
SOURCE: Acer AL2671W 32 in
I had that problem, I sent it to repair, because it was on warranty, they told me that they had to flash its BIOS again, so, that is a software problem. That was in my case, I hope can help you. Sorry for my english.
SOURCE: Acer AT3201W LCD TV
I repaired my Acer by replacing the power supply from
http://www.power-on.com/lcd323-4m.html - $85
Acer would not sell me a replacement power supply.
Note: I needed to solder wires the new power supply to the old one,
the pinouts on the connectors on the new one would not fit the original.
SOURCE: Acer AT2001 cannot use as monitor
I currently own an Acer AT2001 21 inch Television/Monitor. The refresh rate on your computer should be set to 60Hertz. You can change this setting by right clicking the desktop, click properties, click settings, click advanced, click adapter, click list all modes, click 800by600 at 60Hertz. The screen resolution will not go above 800by600. Note; Initialize these settings with an old crt monitor and then plug in the Acer.
SOURCE: Acer 42" LCD AT4220B has vertical lines, need replacement Screen
you should get in contact with customer support for a possible replacement , try this link,
click here:
http://www.partmaster.co.uk/cgi-bin/catalogue.pl?section=159190&link_parent=159196&path=99178
