Question about Kenmore 15864/15862 Top Load Washer
Washing machine cuts off
When washing clothes the machine runs than it will cut off and you have to wait 15 minutes befote it will start
  • 15,935 Answers
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Model IWL12 is showing "Power Cut restart in 10 secs" what is wrong.
Your motor controller board has faulty power supply,
Board needs replacing.
Dec 17, 2012 | Fisher and Paykel IWL12 Top Load Washer
My car run find for about 15 minutes that smoke
if the smoke smells sweet your heater core is leaking is the water level going down if it is replace heater core
Aug 15, 2009 | 2002 Chrysler Concorde
Cleaner cuts out after 10-15 minutes, have washed both filters.
there will be safety relay(OLR) check the settings and increase the settings then chack the operation.
May 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Whirlpool Calypso stops at 26 minutes and throws ob code
first you need to clean your washer
run the washer with no clothes; add 1 cup vinegar, that will cut the soap residue from the hoses do this on hot wash hot rinse
then when you wash your next load of clothes; fill the tub about 1/4 full, add the soap, turn the agitator to disolve the soap, then add the clothes
this problem happens also if you are using too much soap or a heavy duty soap such as Tide.
May 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Car keeps turning off
307 engine? I would try the ignition module.
Mar 27, 2009 | 1983 Oldsmobile Delta 88
Whirlpool washing machine ,
Hello bill197
Welcome,
You said, when you start the machine the program will run round and round it well not stop
but the machine will not do a wash.
How old is the washer
And the model is GHW9150P..??
Try this,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works!
Waiting for your reply!
Please remember to leave a appropriate rating when you are done!
Thank You
Huum
Sep 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
My amanda washing machine
My amana washing machine will not unlock
Mar 21, 2008 | Washing Machines
PF display on my maytag neptune
it stands for power failure. i would unplug the machine for 5 or 10 minutes and that should reset the micro computer.
Mar 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore 15864/15862 Top Load Washer Logo
234 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
