Question about Jl Audio 13W7 Car Subwoofer
I have two Jl 13.5s w7 they only pop
When they pop the low ohm light on the jl 1000 lights up I need to no how to wire them in series. I called Jl audio shop they told me and I wired how they said they still pop So what should I do to check them now I have a Optima battery to
  • kruppalup Feb 10, 2009
    When they are running parallel the low ohm light still comes on but i have to turn it up louder to. the subs are 1.5 ohm and the amp is 1.5 ohm. Some people told me it was the altenator but the car is not even running so how is that then i heard the subs are not sealed right they told me it was my amp then subs voice coils not wired right need another battery I checked the wires like 50 times there is nothing wrong with the wiring. What else should I check
  • Stephen Davids May 11, 2010
    get a capasitor. it is a tank that holds power and doesn't fluctuate any car power. also what kind of popping noise? is it almost as if the sub pushes out instead of pulling in? what wattage is your amp and what is the max of your sub? if its the same amount turn down the gain on your amp you NEED a safe zone, you don't want to constantly run them at their peaks
  • 77 Answers
Greetings I'm Ryan,
sounds like a clipping issue.
if you could please refer to you owners manual for the amp and sub and choose the best impeadance possible. i would recommend a 4 ohm load on those specific subs. but if you could either provide more info on the amp or check this link for wiring diagrams in how to raise the impeadance from whatever you have now to a 4 ohm load. which would be 8 ohm on each individual speaker then ran in series together
http://www.avatarspeakers.com/wiring%20diagrams.htm hopefully this will fixya
let me know if there is further assistance needed.
Good day.
Ryan
Posted on Feb 19, 2009
    Sniper:
  • 86 Answers
There should be no need for a series connection. The outputs on the amp are parallel inside the amp, requiring you to only connect the speakers separately to the amp. With two 4 ohm speakers, you will achieve a 2 ohm output [(4x4)/(4+4)] and be within tolerance.
The Low Ohm light will also illuminate in the event of a short. Check your speaker wiring, looking for any positive leads touching negative leads or for any leads that may be grounded to the chassis of the vehicle.
Posted on Feb 10, 2009
  • Dwayne Bowers Feb 11, 2009
    DOH! I overlooked the dual voice coils. Take a look at this:
    http://74.50.20.110/Wired-in-Parallel.jp..." target="_blank" rel="nofollow" >Speaker Connections
    Now, if you have your individial speaker voice coil pair connected in series and then each speaker connected separately to the amp, you should still be within tolerance. The amp is designed to operate in a 1.5 to 4 ohm range and will adjust automatically to the load. Set your sub voice coils up as a series connection and connect each speaker separately to the amp. Since the amp connections are in parallel inside the amp, you will have a series-parallel configuration running at 1.5 ohm.
    I hope this was more help to you than previously. Nice gear you have there, by the way.
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Jan 14, 2016 | Kicker Car Audio & Video
JL Audio 1000/1 v2 distortion problem
Make sure all your connections are tight , really tight . Check ground , make sure it's to clean shiney metal. Three subs are going to have a low ohm load if paralleled . These amps are not 1 ohm stable ,if below 1.5 ohm's you will have problems. They need to be series paralleled to raise the ohm load. These amps put out the same power from 4 to 1.5 ohms.
Mar 14, 2012 | Jl Audio Car Audio & Video
I looked up the correct way to wire my JL 13.5W7 1.5. Therefore it said to wire it in parrallel. I understand this will put it at .75 ohm. As I start to turn it up it sounds great, very loud but once the...
1000/1v2 Class D Monoblock Subwoofer Amplifier Specifications:
  1000/1v2
Rated Power:
1000 W RMS @ 1.5 ohm - 4 ohm (11V-14.5V)
THD at Rated Power:
<0.05% @ 4 ohm
S/N Ratio:
>95dB below rated power (A-weighted, 20 Hz - 20 kHz noise bandwidth)
Frequency Response:
5 Hz - 250 Hz (+0, -1dB)
Damping Factor:
>500 @ 4 ohm / 50 Hz
According to the chart your amp is only stable down to 1.5 Ohms, so running at .75 Ohms the noise you are hearing is the amp clipping (running more power than it can handle at low ohms)
I would suggest wiring it in series, or you could adjust the gain on the amp until the popping goes away.
Hope this helps.
Nov 10, 2010 | Jl Audio 13W7 Car Subwoofer
Low ohm light stays on my jl 1000/1
you have your amp wired at too low of an ohm load for the amplifier. This is why it is doing this. Jl amps are awesome and pretty much make everything idiot proof. Not calling you an idiot but go online and search for that model on JL.com then look on either the box your subwoofers came in or on the back of your subwoofers. Find out which ohm load they are and how many voice coils. Next go to www.the12volt.com and find the subwoofer wiring diagrams close to the top of the page. Then enter in your information on your sub's impedence and how many you have then it will give you the wiring options that you have and it will probly tell you you are wired at like a .5 ohm load. And let me guess you turn it up too long or too loud and your amp gets hot and it goes into protection.
Jun 09, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Low ohm light comes on and loud humming sound comes from amp and sub have a j1000 and 13 w7
nice set up, how many speakers are you running? you have something wired up weird causing the ohm level to drop to low. we can fix this let me know and ill help you.
Mar 07, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000/1 popping fuse
well you need to check to see if nt no shottage with the amp and also check if the fuse is not to low amp 20,,,, 25 if not put the amp in a separet 12 volt battery
Dec 10, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Jl 1000\1 v2 and 13 w7
it depends on how you wired your 13 w7 did you wire the dual voice coils up or down?? the w7 comes with a book and it has the 1000/1 settings you need and then there is a guide that comes with your 1000/1 v2 and on page 14 it tells you how to set the gain accordingly to your ohm load for perfect sounds with little to no gain overlap (you can set the gain louder if you don't want maximum sq and are not worried about clipping cause a 1000/1 shouldn't blow a 13 w7 from overpowering only from clipping (and since the w7 are practically bullet proof clipping takes a long time)
Nov 06, 2008 | Jl Audio 1000/1 Car Audio Amplifier
JL audio hook up problems!!??
your w7 13's are dual 1.5 Ohm, but according to JL website, are 2.41 Ohms when the coils are in series. Each 13 connceted to each amp with voice coils in series is your best bet. The amps are designed to put out the same amount of power from 1.5 to 4 Ohms. If you parallel the voice coils, you end up with .6 Ohms and the amp will go into protect mode. You'll be drawing a lot of current, so you may want to think about 1/0 guage power wire, upgrade the wire from the alternator to battery (usually only 8 guage) and think about multiple batteries.
Feb 09, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Low ohms light ! ! ! !
How are the speaker wired and what is the ihms for the speakers?
Dec 06, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Jl Audio 13W7 Car Subwoofer Logo
568 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
hoyzee1
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
