Question about Vizio L32 32 in. LCD HDTV
Vx32l has power when turned on i get blue screen no controls
When i turn the tv on it powers up the the screen turns a dark blue
but none of the controls work. remote or the tv i have to turn it off by
unplugging the set. any help trouble shooting would be greatly appreciated since the set is 13 months old the warrenty is up on on my own what luck huh. thanks again for any insight.
  • jamesros Feb 24, 2009
    I turn on the tv and the dark blue screen comes up with no control other than unplugging it.
  • Vegas Fire Apr 17, 2009
    I have the same issue. My problem occured when I was changing signal sources from pay to see cable to over the air antenna. The television turns on and goes to dark screen and then none of the controls work. I have to unplug the tv to turn it off. I just e-mailed tech support and I hope to have an answer soon. What a shame if this two year old tv has stopped working!
    New Friend:
  • 56 Answers
It sound like the main board problem. Replace the main board will fix it. By the way, if you purchased the TV from Costco then the TV is still under warranty.
Posted on Feb 17, 2009
Visio VX32L has a black screen, appears to power on but picture.
Any swelling on a cap is bad sometime you wont see swelling ontop sometimes its on the bottom, I suggest replacing those caps then try again make sure you discharge the caps as well.
Also make sure its the right caps too!
1000uf 6.3volts or something like that. Ebay a good source for caps and amazon.
Dec 15, 2015 | Televison & Video
My Vizio VX32L LCD TV will power on but no picture or sound
I had the same problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound.
HOW I FIXED MINE: I ordered a new "main PCB" from (you can also use This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine. I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272 2174 or it was 3632 0212 0150. Check your circuit and see if any of those numbers match up.
Nov 23, 2009 | Vizio VX32L Television
Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the main power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for a separate board with mostly larger components on it; it will have a ferrite core transformer on it and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on that board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most are capable of switching on and off if a downstream problem is causing an overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
Jul 25, 2008 | Vizio VX32L Television
Blinking red power light - set will not turn on
Were the pale blue lines real thin in a slight diagonal from bottom to top of your screen? If so you either have a bad component in the blue drive, Blue CRT socket or your Blue CRT is shorted.Try removing the blue CRT socket and trying to power up your set for a moment without the blue socket attached to the tube. Be sure the CRT socket doesn't touch any components when you try this. Let me know if the set starts up without the blue.
Jan 23, 2008 | Televison & Video
No picture or sound
Sounds like the unit is in some sort of shutdown. It's hard to pinpoint the issue without knowing the make/model of the unit.
Nov 19, 2007 | Vizio VX32L Television
Tv too dark to see
To get rid of the white lines look at the place where you turned the control. It should be called the screen control, turn down the screen control counterclockwise till the white lines just go away. If the picture is still dark, you will need to have this set serviced as there is a problem in the crt driver board, or the power supply board. good Luck
Jun 25, 2007 | Sanyo DS35510 35" TV
Vizio L32 32 in. LCD HDTV Logo
151 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
