Question about Palm Tungsten T3 Handheld
Can i use other vendor's adaptor that has 5volts? because here in mindanao there is no PALM CENTER, and the 5 voltage adaptor can charge my palm tungsten T3??
    Problem Solver:
  • 9 Answers
Check the current supplied by the adapter. Beyond that, should be fine. I use generic adaptors to charge my MOTO equipment.
--Mark
http://www.marksatterfield.com
Posted on Feb 10, 2009
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Ectaco translation software for Palm Tungsten e
What happens when you try to run them? Did you try reinstalling the programs?
Jan 09, 2008 | Computers & Internet
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
Palm 3892d409
The voltage is printed on a the power adapter.
May 16, 2013 | Computers & Internet
I have a palm treo that isn't booting.
I believe this means your battery is no longer sustaining a charge enough to power your phone. I would recommend replacing the battery. You should be able to buy a new or used battery from your phone vendor or authorized reseller.
Good Luck,
Jesse
Jan 13, 2010 | Palm Treo 750v Smartphone
If I did not charge my palm m515 will it still work? I just got a Palm m515 and I did not charge it for 24 hours before syncing it to the computer. It works fine on the cradle, but it will not keep a...
the m515 uses a Lithium battery .. the modern version of those batteries have a built in safety feature .. once its first activated then it monitors its own voltage .. if the voltage is ever allowed to go below a certain value then it will refuse to accept a charge ... when it tells you that the battery is dead its actually well above that critical voltage .. but if you let it sit for a long time then self discharge can bring it below the critical value .. when the battery is in that forbiden region then there is a chance that it will grow copper links through its insulator .. then when you try to charge it it could get very hot .. even explode .. so thats why the safety feature .. there are ways to jump start the battery and some people do that .. but you can see there is some risk .. the battery in that palm is not hard to change and they are not expensive but you need a very small torques driver to get the case apart .. i just took my 515 to the hardware and had them match it up with the proper tool .. there are kits available also that have a new battery and the proper tools to take the m515 apart .. of course they cost more..
make sure you have the external charger hooked up to the cradle .. it wont charge from the USB port voltage as i recall on this model..
Sep 04, 2009 | Palm m515 Handheld
Is this a battery problem?
If it's not the E2 going to sleep mode ;-), have it checked by a Palm service center http://www.palm.com/us/support/contact/repair.html .It might just need a new battery. Worst case scenario the charging system is faulty. Have it checked.
Hope that helps. Let me know how you make out.
Jan 19, 2008 | Palm Tungsten E2 Handheld
Palm vx hand held
the stylus is that little pokey stick that comes with the Palm.  Use it to tap the X on the screen.  It is an alignment program for the touch-screen.
Oct 13, 2007 | Palm Vx Handheld
My Palm Zire 72 will no longer charge
At first, before to want to be sure where is the problem is, you must do these sample tests: 1) Take out your battery and plug your power cord into your phone without battery. If : Power is on, there is definitely, your battery is bad and cannot hold a charge. If nothing happens, your internal battery may be dead and cannot hold charge so all info in your ROM of course has been washed away except the pre-load software by Palm. 2) At this step, you need to open your Palm if you know how to do to check for any bad connection between cable and use your volmeter to check the voltage output of your inner battery or can be called reserved battery whether it is have any power. If your reserved one has correct output voltage as in specs then check all connection around your power supply part to see any crack or defect. Please reviews the link below for detail: http://palmtops.about.com/od/pdarepair/Maintenance.htm I hope these info will give you some hints.
Apr 10, 2007 | Palm Zire 72 Special Edition Handheld
My hot sync was working fine and now it will not communicate... I have tried everything listed on your website but nothing seems to work please help
My Palm stopped syncing on both my work and home computer at the same time. I have been syncing fine with XP and USB. I found a thread where someone mentioned getting Palm to send you a Palm Reset Card. I called Palm and they didn't offer this solution, but I asked for the Palm Reset Card and it worked beautifully! They took my call and sent the Reset Card no charge. Unfortunately, nobody at Palm seems to know about this solution.
Sep 11, 2005 | Palm Vx Handheld
Palm Tungsten T3 Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Raj Patel
Andrew Taylor
Andrew Taylor
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
