Question about Microsoft Xbox 360 Console
Xbox 360 lost all power
All games worked fine until I started Halo 3, played for 5 minutes then lost all power on the unit.
Have tried unplugging it and plugging back in. No luck.
Did not see "red ring of death"
Any suggestions?
  • 3 more comments
  • mjryan99 Feb 10, 2009
    I just went and unplugged the power from the wall then plugged it back.
    The light on the power adapter was orange. I turned the unit on and it worked.
    Played Halo 3 for 30 minutes and all was well.
    To answer your question the power light on the adapter was green before I unplugged it from wall.
  • Anonymous Feb 10, 2009
    had the same problem. it would lose power and not turn on for a while and when it finally did it got the red ring and i send it to microsoft to get a new one.
  • Aegis Kay
    Aegis Kay May 11, 2010
    Is your Xbox 360 plugged into a plug board with surge protection or directly into the mains supply?
  • Rafael P?nto
    Rafael P?nto May 11, 2010
    The problem occurs with Halo 3 only, or other games as well?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Two things, do you have no power to the xbox whatsoever? Also what color is the LED on your power adaptor?
    Problem Solver:
  • 5 Answers
Probably over heating of power supply.
take a air gun and blow out the little vent holes at each end, also listen to hear if the fan comes on, inside the power supply.
Posted on Feb 17, 2009
My Halo 3 disc is scratched, i have tried all the tricks and it still wont work, i need some help
If this ever happens to you I recommend going to Blockbuster or something and renting a copy of the scratched up game for one day After you have done this follow these steps. 1. Insert the disk, make sure it is readable i.e. playable 2. In the My Xbox section of the Xbox Dashboard scroll all the way to the left until you have the option "play game" now press Y 3. When you press Y you will enter the game details section, scroll down to the Install Game option. 4. Wait a while for the game to install (this will take up some drive space but it shouldn't be too horrible) 5. after the game is installed you Xbox will use the downloaded files to play the game. Insert your original scratched up disk and try to play it. You should be good to go from there. 6. If this still doesn't work your disk is beyond repair
Jul 05, 2011 | Microsoft Halo 3 for Xbox 360
Ever since we have bought halo 3 for our xbox 360 every other game we have purchased and played has froze up including halo 3.It could be in the middle of game play or as we turn the game on.We are very...
likely coincidental timing with a hardware failure likely with the cooling of the unit. if you suspect halo 3 downloaded something you can delete data from the hard drive in dahboard/my xbox/system settings/memory clear out halo 3 data or perhaps wipe/format the whole drive. more than likely the unit is overheating, try moving it to a clearer area, try pointing a fan at it (experiment with placement of the unit and any active cooling you apply) and see if the problem clears. try to clean any dust you can from the unit especially in the ventilation areas.
Dec 30, 2010 | Microsoft Xbox 360 Elite Console - Black
Xbox 360: Halo 3 won't start at all.
If the game wasnt new there could be a scratch on the Cd that has been buffed out but isnt visible, i advise you to contact the buisiness where you bought the game and exchange the disc or try getting it buffed again for 6$. If they wont replace the game for free try a buff so its cheaper, and if all doesnt work but im sorry you will need to buy a new copy.
Hope this helps ^^. Please dont forget to rate, Thanks
Mar 03, 2010 | Microsoft Halo 3 for Xbox 360
My xbox 360 works fine playing the games that are demos
there might be a short.
other then that i might just think that your power adapter is failing and you need another one.
Dec 01, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Hwhat does it mean when it wont read one game but will read another
it means the one that wont read is scratched, dirty or defective, my advice is to clean it if its dirty, get a cd repair kit if its scratched or take it back if its defective.
Sep 13, 2009 | Microsoft Xbox 360 Console
Xbox 360 halo problems
my halo sometimes does the same thing when i start up the game but pressing a usually gets you through it, but if your xbox 360 overheats within minutes and is an older xbox 360 its usually a burnt out fan or just full of dust, if its old then ur warranty might already be out and if it is just open up the xbox and use an air compressor or anything else to get all the dust out of the xbox. in my case everything was just caked with dust. anyways... good luck
-Armand M.
Jul 24, 2009 | Microsoft Xbox 360 Console
Xbox wont read my discs (except for halo 3)
i have the same problem. try adjusting the pots and clean the lens. i might work. in my case a games start working. but i have ordered a new laser lens online. still havn`t got it. i think that will solve the problem
Jan 27, 2008 | Microsoft Xbox 360 Console
Xbox 360 quit playing the new 360 games
I would take it back for a new one...
Halo 3 is notorious for overheating the console...
check out www.360problems.com
Dec 26, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
132 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
