Black smudged horizontal lines during printing
The top 1/2" of the thick vertical bars in the nozzle test pattern are smudged toward the right and slight gray smudges appear every 2 inches in the grid. It's like something is smearing the perfectly good print. I already cleaned the nozzles, deep cleaned, and cleaned the roller, but I haven't touched anything inside to manually clean it.
Try cleaning your rollers, it worked for me. I hope this helps.
SOURCE: Black Printing is bad.
have you tried running the cleaning options? that may help. or is your black ink running low?
SOURCE: new ink cartrage
Print Nozzle Check Pattern
< 1 > The normal nozzle check pattern
< 2 > The abnormal nozzle check pattern
< 3 > Some black ink lines are broken.
< 4 > White lines are present in the color ink pattern.
< 5 > Both black and color inks are not present.
Note:
Print Head Cleaning:
Deep (Print Head) cleaning:
Note:
Do not do any other operations until print head cleaning is completed.
Note:
Do not do any other operations until print head deep cleaning is completed.
Note:
Ifthe printed result does not improve even after doing print head deepcleaning, turn off the printer. Then, after 24 hours or later, do printhead deep cleaning again. (After a given time interval, ink coulddissolve itself, resulting in ink unclogging.
SOURCE: Lines running horizontally across the printed colour page
Checked ink cartridge's, two had dried out, still had ink in them but the exit apertures were blocked.
So new set of ink cartridges and problem fixed.
Thank you
Jim
SOURCE: Printing anything in black comes out with horizontal blank lines
Have you tried updating the printer driver (first uninstall the existing driver and make sure you have the latest one already saved to your PC before starting). I don't think your current one has mysteriously misbehaved, I suspect that it has been corrupted in some way (a new download may have done something to a critical part of the driver). By deleting and re-installing you are "refreshing" everything. Good luck!
