Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
I need to find out the making year of my washer Whirlpool Ultimat
Hi, If anyone can help me to find out the making year of my washer Whirlpool Ultimate Care 2, model LSQ7030LQ0 and the serial number is CM4924632.
I bought it second hand without papers. Thank you so much. Elena
    Sergeant:
    Champion:
  • 373 Answers
You can call
1-877-922-2880
Posted on Feb 10, 2009
Model # SM 8280867 How old is this model?
6 - 10 years in 2012
Whirlpool Washer Ultimate Care ii - Appliance Repair Forums www.applianceblog.com/.../32099-Whirlpool-Washer-Ultimate-Care-ii
  • LAST UPDATED: 2012-05-28
  • 6 POSTS
  • FIRST POST: 2012-05-28
Whirlpool Washer Ultimate Care ii Model Number: SM 8280867 Brand: Whirlpool Age: 6-10 years Hello, The washer ...
Jan 27, 2016 | Washing Machines
Tip
Found your post after googling around a bit - I was able to figure out most...
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
  1. Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
  2. If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
  3. Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
  4. Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
  5. Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
  6. With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
  7. With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
  8. Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
  9. Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
  10. Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary. If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature. For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website. Just type in your COMPLETE washer model number and look under the Agitator Parts heading. I hope this information is found to be helpful.
on Oct 22, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
I have two questions-1. Why is the Whirlpool front load washer/dryer so cheaply made? We have only had our duo for approximately 5 years and the plastic, where the buttons are, are cracked on both...
I know what you are saying and fully agree. most makes are designed to last around 4--6 years...rightly or wrongly depending on your point of view , new costings are down now what it used to be say 10 years ago......discolouration can be if its used in a cooking area ,oils and fats attack the plastic parts colour/ also weaken plastic posts hence the snapping.....hope this helps you....
Mar 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Need to know what year is my washer set
The date of manufacture is determined by the SERIAL NUMBER, not the model number. The serial number will be located on a nameplate (with the model number) along the wash tub rim under the lid.
The following link explains how to read the serial number to determine the age:
http://www.fixya.com/support/r3576437-determining_the_age_of_your_whirlpool_ap
The 2nd digit in the serial number will identify the YEAR is was manufactured. The first two numbers, following that digit, will determine the WEEK (52 weeks in a year). This same information applies to all your other Whirlpool appliances.
If you have any questions, please post back and let me know. I hope this helps you.
Dec 18, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hi i have a windows 7 ultimat 46 bit and i want
If they dont have it on the canaon support page, and the driver they do have wont work, even in compatability mode, your pretty much stuck, you will have to search for a printer that is x64 compatable
Jul 15, 2010 | Canon LBP 800 Laser Printer
Whirlpool washer age please-Type 3 cp 2302342. LSN 2000LW1
The manufacture date of Whirlpool appliances is determined by the SERIAL number. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
The first two sets of NUMBERS represents the WEEK it was manufactured, while the second DIGIT represents the YEAR. So...based on the serial number you have provided, that would make the manufacture date of your washer June of 2003. Let me know if you have questions. I hope this helps you.
Oct 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
317 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
