Question about Dell XPS M1530 Laptop
Battery Locked the lock switch to the battery was accidentally switched on and now i cant switch it back to 'unlock' so that i can get my battery out
  • 4 Answers
i think you want take battery from ur laptop is it right. for this 1st you close ur laptop & turn back near to the battery there will be small lock(button). you just release the button and remove the battery.
Note:- Make sure you should shutdown all the applicarion and is not in the AC power.
Posted on Feb 12, 2009
How to install sim card
1. Slide battery door switch from locked to unlocked.
2. Remove battery door by prying up in the notch are that is provided in the bottom corner.
3. Slide battery lock switch to unlocked position ( this is located at the bottom of the battery and slides from left to right or right to left depending on if the device is locked or unlocked.
4. Remove battery from the device.
5. In the bottom left hand corner you will find a small metal tray that has a rubber flap covering the front of it. Pull up on the rubber flap ( it stays connected to the phone ).
6. Look for the SIM card picture to show the correct orientation of the card.
7. Slide the card into the metal tray and the replace the rubber flap by pressing down on it firmly.
8. Replace battery and slide battery lock switch to the locked position.
9. Replace battery door and slide the battery door switch to the locked position.
Jul 11, 2014 | Casio G-zone Commando
My SD card is locked and i cant get it unlocked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 24, 2011 | Vivitar ViviCam 5024 Digital Camera
1999 porsche 996 replaced key fob battery disconnected battery now trunk releses are locked and cant access battery.How do you open frt trunk manually
Assuming the car battery is ok (if not, buy a male to male cigarette lighter at the auto store and connect to another car until charged enough to unlock the doors...but don't try to crank the ignition!). The trunks won't open if the battery went dead with the alarm set because arming the alarm physically locks the releases.
Sounds like the key code is switched off because you replaced the key fob battery. Try unlocking the car manual with the key in the door lock. Then switch the ignition on to reactive the keyless entry. If this does not work, you might also try pressing the fob unlock button with the key in the door lock until the dash led flashes.
Jun 10, 2010 | 1999 Porsche 911 Carrera
SD card Locked
The error code 000060 means SD card locked. The switch on your card may be unattached internally. Try a different card.
May 17, 2010 | Moultrie MFH-DGS-200 Digital Camera
Cant get to security menu
See, when you unlock your phone you keep it unlock untill next switch on. Switch off and then switch on and chek if locked.
Aug 13, 2009 | Kyocera Cell Phones
Sd card not working
Check to make sure you didn't accidentally move the locking switch on the SD card to the locked position. There will be a switch on the side of the card. One side of the switch says locked, (or has picture of a locked lock) and the other side says unlocked, or has a picture of an unlocked lock. Try it out.
Dec 31, 2008 | Nikon Coolpix L11 Digital Camera
Cant open or release battry latch[presario v 4000]
There is another little switch like slide near the side of the laptop towards the end of the battery compartment. This a lock for the battery latch. Slide the switch to unlocked position and then try releasing the battery again. When you put the battery back or a new battery in , be sure to slide the switch to the locked position. This is just an extra feature to make sure you're battery won't fall out. If this solved your problem PLEASE rate this as fixed. If not do not rate yet just add a comment letting me know what happened and I'll be glad to assist you further. Thanks and have a nice day.
May 02, 2008 | Computers & Internet
Locked keys
Hi. I have a different Jwin model radio to yours, but they might have this in common: is there a 'hold' button on yours? If so, this is used to 'lock' all the buttons so that you don't switch it on/ change stations etc accidentally. Look for a 'key' symbol on your display, and press AND HOLD the 'hold' key until the symbol disappears. Pressing the 'hold' button briefly will make the symbol re-appear, and lock the keys again.
May 18, 2007 | Jwin JX-M20 AM/FM Radio
Dell XPS M1530 Laptop Logo
Alun Cox
