Question about Kyocera FS-2000D Laser Printer
CALL SERVICE 7410:0002988
HELP ME WITH THIS PROBLEM! KYOCERA FS 3900DN
  • Anonymous Apr 06, 2009
    code 7410
    Genius:
  • 2,120 Answers
Turn printer off
open left door
push in DRUM unit
turn back on.
Posted on Feb 10, 2009
    Sniper:
  • 66 Answers
The 7410 error may be a drum unit that is not pushed in properly or it could be the following
defective drum EEPROM drum needs to be replaced or
defective engine PCB
the above suggestions assume that it is an original Kyocera drum
hope it helps
Posted on Mar 21, 2009
Hi, open the door on the left site and take out the bottle
und check the gray lever
also check the whole black unit
(for example knock on the black unit)
maybe it ist only to lax in the holding device
Posted on Mar 23, 2009
4 Suggested Answers
n25an
  • 622 Answers
SOURCE: What does mean Kyocera FS-3900DN Call Service 7410:0020192 ?
take out your paper tray... drum and developer and then pull out the paper
Posted on Dec 24, 2009
  • 241 Answers
SOURCE: kyocera fs-3900dn showing 7410:0024216 error code
The 7410 is a drum installation error code. This is typically caused when the waste bin is replaced. Open the left door and push on the drum unit just above the waste bin, usualy a click will be heard when pushing it in. Then power cycle the printer. This should fix the error message.
Posted on Jun 09, 2010
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
Kyocera call service 4200:040797
Means that the laser unit is off. You should check the cables for the laser unit
Jun 27, 2014 | Kyocera Mita FS-3820N Laser Printer
I have Kyocera FS-3900DN , it shows on the display error code (call service 6030:1022274) thanks
This problem is caused by a poor contact in the fuser connector terminals.
Check both sides of the connection (in the printer and fuser unit) In most cases we will find small pieces of paper inside printer connector causing poor contact between printer and fuser unit connector.
Hope i was of any help. If i was, please rate me.
Thank you.
PcSimples
Mar 14, 2011 | Kyocera FS-3900DN Laser Printer
Kyocera FS-3900DN Ecosys Call Service 2200:0100998 Help please our printer has stopped working
The Call Service 2200 is a drum motor error. The motor or gears might need to be replaced. First remove and re-seat both the developer and the drum unit. The developer is directly under the toner cartridge - lift it up then out first, then open left side door remove the waste bin and press the button on the drum unit just above the waste bin pull the unit out (carefull not to touch the drum surface). Re-seat both units. If this does not work call in a Kyocera Tech.
May 07, 2010 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
My ecosys fs-3900dn printer gives this error 0150:0119695
It is a "mechanical error". The part after the colon is the number of pages printed. It's probably worthwhile taking the trays, toner and cartridge out and opening all the access doors and checking for something obvious before calling in an engineer.
Jul 19, 2009 | Kyocera FS-3900DN Laser Printer
Kyocera Ecosys FS-3900DN in HP emulation mode
Right click on the printer icon and choose properties. Your emulations are listed there.
Jan 14, 2009 | Kyocera FS-3900DN Laser Printer
My Kyocera fs-3900dn has the message: call service 0150:0040557. What does it mean?
0150 - Engine PWB EEPROM error. Detecting engine PWB EEPROM communication error.
Solutions:
1. Switch the printer OFF; unplug the power cable; wait 20 seconds; plug in the power cable; switch the power ON, If the error comes back follow the next solutions:
2. Update / Burn the latest firmware version. You may need to call a Kyocera Service Provider because you need a CF card (compact flash memory card) and the FIRMWARE.
3. Replace the Engine PWB (a board) - again you have to call a Kyocera Service Provider.
Dec 30, 2008 | Kyocera FS-3900DN Laser Printer
Service code
This is a laser problem. The polygon motor probably got jammed usually it needs to be cleaned and oiled or the motor has ceased.
Mar 10, 2008 | Kyocera FS-3900DN Laser Printer
Kyocera FS-2000D Laser Printer Logo
1,956 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
