I have a 19 in. soyo monitor that works when powered on but the sceen display is very dark, just enough can be seen to show that it is working. brightness adjustment don't work. Is there some other backlight or somthing that can be replaced? Help with this would be great. thanks
-   I have one soyo 19" that shows the same defect. the problem is the inverter and I don't have the skills for seek the components and repair. I'm looking for a service manual or something.
Hi yes it looks like the inverter has failed and will need replacing, or if your compitent enough you can fix it at board level. The usual suspecs are a small SMD fuse on the inverter board / power supply board and/or buldging capacitors which look like blue or black cans.
hope this helps.
jonno
Was this helpful?
Yes
No
Popular Solutions for Soyo 19 LCD Flat-Panel Display
I have a soyo 19" flat-panel display for computer that flashes on (blank screen)and back off...
(More)
I have a soyo 19" flat-panel display for computer that flashes on (blank screen)and back off again and then repeats. Any ideas?
monitor flashes RGB in top left corner and shows images when turned on then goes black model...
(More)
monitor flashes RGB in top left corner and shows images when turned on then goes black model #MT-NI-DYLM1998
