Question about Toshiba Satellite A45-S121 Notebook
It will charge
But when you press the power button the lights come on like it will start up but does nothing. I have taken it apart and put it back together but same thing.
  • alissaandnoa Feb 10, 2009
    can i check the battery cell and the charger with a volt meter
    the battery works in the other laptop and it is fully charged
  • 6,784 Answers
This is a bad battery cell. it is unable to hold a charge. it will unfortunately have to be replaced.
Posted on Feb 10, 2009
  • 2 more comments
  • Michael Masters
    Michael Masters Feb 10, 2009
    the power supply board may have minor solder breakage but, im sure its the battery core itself not being able to hold that charge
  • Michael Masters
    you can check the charger but, the batt core is dead. you wont get a reading from dead cell core.
  • Michael Masters
    ok, its the power supply board that is failing to transfer the power. im sensing a solder crack that should be repaired.
  • Michael Masters
    its probably the solder joint that connects the power switch to the board. its a minor separation.
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Mar 31, 2012 | Computers & Internet
My samsung N150 power switch is not working
The Switch ON? Are you talking about the Power Button? If so it could be that your Power Cord is bad. Some models of the Power Cord has a light on it and some laptops light up somewhere when the power cord is plugged in and working.
You might have been working off your battery and if the power cord is bad it was not charging the battery and now nothing will work because the battery is completely drained.
If the power cord is good, you might have a Static Charge Buildup. Remove the power cord and the battery, then press and hold the power button for 30 seconds. After 30 seconds put the power cord back in (not the battery, leave it out) and press the power button. If it starts booting you had a Static Charge Buildup and can put the battery back in now.
If all fails, take an ink pen and stick it inside where the power cord goes. If it is not tight then the DC Power Jack is bad and need to be repaired. This will require a complete disassembly of your laptop.
Mar 23, 2012 | Samsung N150 (36725723009) Netbook
Advent 4211-C won't power up on AC or battery. The only sign of life is the battery charging light which displays green continuously when the computer is plugged in to the mains... apart from...
You may have already tried this... Please remove the battery to see if the machine responds to pluged in power by itself. Press the power button for about 30 seconds befor pluging in the power... this is usually the way to reset the laptop. A defective battery can keep the machine from working.
If there is no response, the motherboard may have been damaged or a solder gotten loose, either way, it would need to be taken apart to verify and the solution could be expensive.
Aug 25, 2011 | Advent 4211c Notebook
Presario C700 won't turn on after installing new screen
Why was machine taken apart? Did you check memory to make sure it's sitting correctly?
Jan 06, 2010 | HP Compaq Presario C700T
D600 laptop boot problem
The D600 is plagued with power up problems for 2 reasons. First the connector on the motherboard to the power button is very sloppy and after awile it breaks contact. If you put pressure under the docking port area and press the power button it may start. The second is the memory slots. I know you said you replaced the memory, but it is the slot that is a problem. Remove the memory and put 1 chip in "A", then press down on the chip while trying to boot the laptop. If this works then get a peice of foam or pad and place it on the chip. When you put the cover back on it will push down on the chip and should boot. Repeat this process for "B".
The green light does signify a charged battery! This is also a possible reason for not booting. Remove the battery and try to boot with only the power supply. A shorted battery will stop the laptop from starting up.
If all of this does not help then remove the battery and the CD Rom, then try to boot. Finaly if nothing helps you should buy a new Laptop or a used one on E Bay. You could get a used D600 on E Bay that has a good motherboard for cheap money and use your drives and LCD. I work on D600 and D800 all the time. Let me know how you make out!
Dec 09, 2009 | Dell Computers & Internet
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
Nothing happens when I press the power button except the light
Regardless if you don'r feel comfortable taking the comouter apart it needs to be taken apart and looked at. Depending on what got spilled inside the sooner the better. If it was a soda of some kind it could be bad.I would take out the battery and not try it again.
Oct 03, 2008 | IBM ThinkPad T60 Notebook
Toshiba Satellite A45-S121 Notebook Logo
32 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
