Question about Canon imageCLASS D661 Digital Printer
The bulb is no longer working on the copier.
When I attempt to make a copy, everything moves, but the light is not on. Is there a way to replace the bulb?
You can always buy a new one, <>
Posted on Feb 10, 2009
Indicates warming up when you try to copy or scan anything
Lift the lid and check the scanner light when you attempt to copy or scan. If it is not lit, then that is your problem. This is a relatively old device, and uses a fluorescent lamp. These require a short warm-up time that will increase as the bulb ages and eventually the bulb will fail. At that time the warm-up indication will remain since the bulb never reaches temperature. Based on the age of the unit (first release 2004), if the lamp is bad, it would be prudent to get a new unit.
Sep 16, 2015 | HP Photosmart 2610 All-In-One InkJet...
Spotlight wiring
Copy following link for troubleshoot resources and tips to get power pack to last longer.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
The lights don't have bulbs?/ This is not clear.
Buy new bulbs.
Be sure to unplug power pack when working on lights, or power pack can fail.
Jun 30, 2013 | Malibu Hardware & Accessories
Heater works but there are no longer any "flames."
There are bulbs that can be replaced.
Consult your owner's manual for directions, or call Dimplex for a new copy of your owner's manual.
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex DS5598 Mid-Size Heater
When i try to make a copy it comes out all black and when I try to scan something it is all black
Check the scanner bulb - it's suppose to light up when you copy or scan. Look inside the scan bed and as you copy or scan, it should light and move across the bed.
Feb 01, 2011 | HP PSC 1610 All-In-One InkJet Printer
I want a service manual for my canon pc940 copier
Just installed a new cartridge. Made one copy. worked great.
Went to make a copy today. All Black. Thought about it. Tried again and noticed lamp was not lighting. Before you say DUH! is the lamp out or is their extenuating circumstances preventing the lamp from lighting during a copy. The table top moves and everything else seems to work accordingly.
Sep 27, 2010 | Canon PC-940 Black and White Copier
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Makes only black copies.
Hello sir; when you make a copy open the cover then yo can see does the exposure lamp is on if not replace it.
Aug 23, 2009 | Minolta Office Equipment & Supplies
Copier Mode - will only copy in colour.
Electronic problem possibly. Contact manufacturer or simply replace it if bought new.
Oct 21, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon imageCLASS D661 Digital Printer Logo
50 people viewed this question
old marine
old marine
