Question about Cobra 25 LTD 40-Channels Base CB Radio
Cb Radio blows the 15 amp fuse in the car when powered up
This is a cobra 25 nw ltd I got it at a yard sale with great aspirations of fixing it myself, then I realized i don't know squat about electronics. When powered it just blows all the fuses.Anyone have any ideas where I could start?
  • billybb17 Feb 10, 2009
    I changed that diode. It blows the fuse in the red wire and the fuse (15) amp in the fuse box of my vehicle
  • billybb17 Feb 11, 2009
    Helpful but how do I find the cap thats shorted in the final?
  • 170 Answers
Look where the hook up wire goes into the circuit board. Find the protection diode.Round small black cynlinder with a silver band. cut the diode and run a continuity check across the positive and negative. If all checks out try to fire it up.15 amp fuse is way to high for that radio use 5- 7
Posted on Feb 10, 2009
  • Tom Arsenault
    Tom Arsenault Feb 10, 2009
    Might have a shorted final or cap around the final stages
No Receive on cobra 25 nw ltd classic cb radio how to fix it
first make sure its on cb not pa. next make sure the squelch is all the to the left. now make sure your volume is open enough not to blast. If you can hear anything you are good if not you need to take it to a tech.
Jun 16, 2012 | Cobra 25 NW LTD 40-Channels Base CB Radio
II dont drive truck anymore so i got rid of my cobra radio but i still have the ext. speaker. i figure i will come up with another use for it but i dont know the output voltage that was on my Cobra 29 NW...
hi most speakers of this kind are 8ohm or 4ohms you will not do any damage to it by connecting any cb radio or stereo so dont worry as long as you dont plug it into the main power source haha goodluck
Jan 14, 2011 | Cobra 29 LTD CB Radio
I just wired my cobra 25 to the battier and it still squeals what do i do
have your antenna checked, the powers not getting out the antenna so its feeding back thur the radio
Dec 28, 2009 | Cobra 25 NW LTD 40-Channels Base CB Radio
Have cobra 29 nw ltd keeps blowing fuses inline and in cigarette lighter adapter adapter is 10 amps and inline is no more than 5 amps
This is an easy fix if you are comfortable soldering.
You must have hooked it up backwards. Big problem when using a cigarette lighter adapter. You have to be careful, if you hook a radio up backwards you blow the polarity protection diode.
  • Go to radio shack and buy an N1004 diode.
  • Open the radio
  • Look towards the back right of the radio for a black diode D23. it will probably look burnt, but not always.
  • Use a soldering wick to remove the solder holding the diode in.
  • Remove it, and replace the diode making sure its going in the same direction as the old on. Strip on the side the triangle is pointing.
  • Solder it in.
  • Test the radio
That should do it.
Make sure you are careful to hook the radio up to power corrctly.
Nov 14, 2009 | Cobra 29 LTD CB Radio
What Voltage Does The cobra 25 ltd classic use?
12 volts, around 15 amps. For a base station, try an Antron-99 groundplane antenna.
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
How can i connect the volume of my radio
Do you have a Microphone plugged in? No Mike No sound on these.
May 23, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Yard sale find
red should be 12v black should be ground test is on a car battery.
Mar 09, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Fuse
There are only a couple of components that could cause the fuse to blow. They are:
1. Reverse protection diode (D23)
2. filter capacitor (C123)
3. Outputs (TR14 & 15)
4. Audio Amp (IC4)
5. Zener Diodes (D22 & 19)
6. the fuse itself (it should be 2 Amps
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Feb 12, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 LTD 40-Channels Base CB Radio Logo
433 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
