Hitachi projection tv.7years old.can i clean or change the bulb,w
Tv works good,but picture getting a little darker.model # 57GWX20B
  • krusty5 Feb 10, 2009
    thanks,racer7x will try it,just in case , where can i get the lamp from. dont have a part number,thanks krusty5
  • Anonymous Apr 25, 2009
    yes i have 65' projector tv old big one will the pic is good but there is a big black bubble kind of going up on screen it taken half the pic of in a round black circle help please email me at thanks alot
  • 42 Answers
Remove the front screen
Carefully Remove it
Pull the bottom off
Then remove the screws on the bottom of the screen
when you have them off lift the screen assembly up
be careful of the wire going to the panel
you can move the screen to the side and gain acces with out unplugging the wire but again be careful
clean the mirror and the projection bulbs
with glass cleaner and spray only on to the rag not the mirror or projection bulbs
Put it all back together and your picture should be bright as before
Posted on Feb 10, 2009
  • tom woodward
    tom woodward Feb 13, 2009
    You do not have a lamp on this model
    It is a crt projector
Tv is about 6 years old hd-ila 56g657 have replaced lamp 3 times over that time but the picture started to get darker and darker.the last time i replaced the lamp it did very little good and the ptcture...
you cleaned the reflector glass, then tried to make the manual adjustment of the color to have good convergence. you can do the adjustment in the menu set up. if can not get with adjustment, their might be a problem in the convergence circuit board.a bad convergence ic or resistor.
Nov 18, 2012 | JVC HD-56FB97 HDTV
How to fix fix my Hitachi Projection TV - model # 61WX01W, got darker and darker and now all dark. Has 3 pictures tubes. How do I fix the problem?
Likely what you have is the three tubes each have a filament--not unlike a light bulb-----someone would have to trace the filament voltage (usually comes from power supply) from source to the three tubes---filament connects to each tube with two connections and is usually 6.3 volts.
May 05, 2012 | Hitachi Televison & Video
Tv got dark and darker and now no picture what can be wrong? bulb bad?
If the model number indicated here is correct that set uses 3 picture tubes.
No bulb used on that model.
If model number is correct let me know and I have a few suggestions.
May 03, 2012 | Hitachi 61SDX01B 61" Rear Projection...
How to fix my hitachi 65 tv
If you are saying that the picture is getting darker and you have already tried to adjust the picture through the menu feature on your TV then it is more than likely the cooling fluid around the CRT tubes. Over time the fluid in these tubes gets cloudy and causes your TVs picture to become dull and distorts the color. You can google tv repair kits .com and I believe they will have a kit for your model.
Feb 21, 2012 | Hitachi 57F500 57" Rear Projection...
My hitachi 57gwx20b tv will not turn on anymore, it is getting power but will not turn on?? why?
no solutions for this model (even from Hitachi). Must check for blown fuse. If blown then check HOT. If you can't then have a qualified tech look at your TV.
Feb 26, 2011 | Hitachi 57GWX20B 57" Rear Projection...
Picture is gradually getting darker
It sounds to me like your bulb is going out. You have a rear projection TV, and since so, there is a bulb that shines the image onto your screen. Because of this, you need to replace the bulbs after awhile. Call customer support or look around online for a replacement bulb and directions on how to change it. Very simple, but takes a little time and effort. :D
Mar 20, 2010 | Hitachi 46F510 46" Projection HDTV
Picture seems darker or less intense light
You will need to post tv brand and model number
Feb 27, 2009 | Toshiba 50A60 50" Rear Projection...
Darker picture
Clean the lenes inside of the TV and the mirror and screen (a little dust build up on these three things adds up quick!) also if you smoke that can build up too! these tvs have too be cleaned inside
Nov 28, 2008 | Hitachi 57F500 57" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Televison & Video Logo
455 people viewed this question
Top Televison & Video Experts
