Question about KitchenAid KSSS36QK Side by Side Refrigerator
Can't get freezer to cool below 10deg F
The temp in the freezer doesn't get below 10 deg F in spite of coldness dial adjustment. This seemed to happen suddenly not gradually as if a part failed not a coolant leak. In fact coolant has been recharged by local repair guys but no improvement in cooling. Removing the cover at the top does give a degree or two improvement.
  • 1 more comment
  • olsonplace Feb 09, 2009
    The thermometer I use to monitor the freezer temp recommends a range of -10 to 0 for frozen food storage and we like our ice cream frozen very solidly.
  • olsonplace Feb 19, 2009
    Thanks to rockitman 187 and freetek for their responses. After trying suggestions the problem is essentially unresolved. Temp goes no lower than 8 to 10 deg F. in freezer despite dial adjustments or location of thermometer or reading only after door has been closed all night.
  • Randy Hough
    Randy Hough May 11, 2010
    Why are you trying to get below 10 degrees,A normal freezer setting would be 28 - 30 degrees?
    President:
  • 2,559 Answers
Try this and let me know the results.
Place the freezer thermometer between two frozen objects such as two packages of vegetable
and leave it for at least 24 hours before checking. Place the refrigerator thermometer between objects too, such as between two cartons of milk. This is so that the thermometer gives you a better picture of the consistent temperature rather than quick fluctuations as when the door is opened. Read the thermometers after a quiet period when the door has not been opened for a while such as first thing in the morning. It is a good idea to leave the thermometers in the appliances all the time.
If, after checking the temperature, you find that it needs adjustment, do not panic. Both the refrigerator and freezer will have a temperature control dial of their own. The dial will have arbitrary numbers on it like “1, 2, 3, etc.” but will give no indication of actual appliance temperature. One end of the number scale will be labeled “colder” while the other end will be labeled “warmer.” Just set the dial one number closer to the warmer or colder end of the scale. Give the appliance 24 hours to reach and maintain the new temperature and check it again with the thermometer. If you are unable to get the appliance into the proper temperature, it is important to continue troubleshooting by checking the need for defrosting. Also, check whether the door seal is intact.
Posted on Feb 10, 2009
  • Randy Hough
    Randy Hough Feb 10, 2009
    Correction on the clarification question. Meant to say between 28 - 0 not 28-30.
    Sorry for the typo
  • KitchenAid Master
  • 5,568 Answers
For Olson- most combination units have a diverter that allows you to balance the flow of frigid air between the fridge and freezer. It may be located in the rear of your unit since the main cold air flow is done there.
Rockitman - not sure which temperature scale you are using - Olson specified 'F' and normal ranges for the refrigerator would be +35 to +45 degrees and freezer temps are recommended as -5 to 0 F. +10 degrees F wouldn't ensure that food would be very well preserved. Indeed, foods with any amount of salt in them may age at +10.
Posted on Feb 09, 2009
Fridge 700br 2 drawer Built in unit over cooling ,
You should consider a service call. This can happens when the thermostat is failing or when the refrigerant is under charged.
Mar 19, 2015 | Refrigerators
How to lower freezer temperature
Not sure what you mean by the freezer too cold? The freezer section should be at or below 0 degrees C or 32 degree F. if its working properly. If the FF section is too warm and your temp control door or vent is at max cold either the vent is not moving (stuck in the closed position) or the fan in the freezer is not working.
Nov 10, 2014 | Frigidaire Refrigerators
Kenmore795.77304600 bottom freezer will not stay cold. frig part ok. freezer ranges in temp between 37 deg and -10 deg
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Feb 25, 2011 | Kenmore Refrigerators
Vegetables kept out of the crisper drawer feeze up why does this happen even the temperature control is set below 1 on the dial
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 19, 2009 | Refrigerators
2001 GE side by side refrigerator model TGX26KRDA WW Beginning about a month ago the refrigerator temperature rose to 60 deg. F. Freezer remained well below 0 deg F. Checked baffle which was open and...
Is the fan that moves the air from the freezer to fridge running If there is a switch in cabinet somewhere the freezer door would contract it, with door open push in switch hear the fan both are good. Don't hear fan check evaporator or freezer fan and that switch it may be a duel switch open light closed fan run. Tricky there are light switches, when out light on or when switch is in its lights out
Mar 17, 2017 | GE Refrigerators
Freezer temp
Hello I can help with this problem , You can set it to the factory setting thats normaly in the middle , wait 24 hours for temps to equalize and check temp in freezer with an accurate thermometer it should be -10 to +10 deg. Far. to adjust temp move dial up or down only one digit at a time and wait 24 hours on each adjustment until its at a correct temp.
Dec 30, 2008 | Kenmore 53612 / 53614 Side by Side...
KitchenAid KSSS36QK Side by Side Refrigerator Logo
243 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
