Minolta Master
- Posted on Feb 14, 2013
Re: CF1501 error code c0650
C 0650 Scanner home sensor malfunction.
Remove the original glass and clean the home sensor(the sensor is dirty,paper dust) located in the rigth rear corner.Move the mirror assy to maximum right position and you located the sensor.
Thanks for the info which helped me to resolve this issue. The CR1501 error code C0650 can also be caused when the scanner is stopped during it's cycle. This can occur when an end-user switches off ther machine without properly shutting down. To repair this fault, open the front cover, get a small watchmakers screwdriver (or paperclip), locate the master reset switch which is in the lower right hand area - it a hole approximately 2mm in diameter. Push the screwdriver or paperclip into the hole to reset the machine. If you removed the top glass this will need to be replaced or you will get a different error code complaining about scanner CSD gain. Hope this helps.
