Question about Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan
Wiring Hunter 21871 fan to Lutron Maestro MA-LFQHW wall control
I'm trying to wire a Hunter 21871 ceiling fan to a Lutron Maestro MA-LFQHW wall control. I do not need a remote control, so I'm not installing the remote control canopy module that came with the fan. How do I connect the red, black, yellow and white wires from the Lutrons canopy module to the red, black, yellow, pink, gray and white wires coming from the Hunter fan?
extreme7528
  • 108 Answers
SOURCE: Hunter fan wiring
sounds like one of your connections is loose. Im not sure if i completely understand your description of how you re-hoked up your fan. Please tell me how many wires your fan has and colors and how many wires you have on the sensor remote. (lots of times if you draw a wiring diagram on paper you can figure it out) Basically you should have power coming from ceiling to remote sensor. Then the remote sensor should throw the power to either the fan or the light, so there should be two seperate leads coming out of the remote sensor to control either the fan or the light independantly.
Posted on Oct 07, 2009
jyackle5
  • 8197 Answers
SOURCE: Need diagram for hunter fan with light kit. Three
Black to black. from fan
Blue to Black and white. from fan
White to white. from fan
The input is from ceiling supply
the black wire from fan is for motor.
the black and white is for the light.
Posted on Jan 02, 2010
  • 351 Answers
SOURCE: The canopy doesn't seeem to fit flush up against
You just need to wrap it and tuck it .. You might need to cut some of the fan wires shorter so there is not so much bulk under the canopy cover. The fans are shipped with enough wire leads to be able to use a down rod, They can be cut shorter when the fan is being installed.
Posted on May 06, 2010
SOURCE: Hunter Ceiling Fan 25885 remote won't turn off light
I have this fan model. The RED is a common wire. Wire it in with all the white wires. Better yet why don't you just bypass the module for the light. You could buy a more up to date Lutron wall switch W/remote control. The Black wire W/White stripe coming from the module is the light control. Cut & cap this with a wire nut. The same wire coming from the fan motor Connect it to your new wall switch. Now heres the tricky part. You have to run a new (Non switched) hot wire to your fan this will connect to the module normally. This is the new power for the fan. The remote that comes with the fan can serve as the On/Off 1,2 & 3 speeds. You now have two remotes. One for the fan the original and one for the light control w/wall switch. The new Lutron model will give you full dimming capability for incondesent bulbs. It is much less noisy when you are dimming the light down.
Posted on Jun 13, 2010
  • 57 Answers
SOURCE: How does the receiver of
if you look at the mount bracket where the ball of the fan fits in to it should fit right above the ball in the mount bracket and if it can fit loose in the canopy thats ok to just long as ou can get the bell housing back up
Posted on Jan 23, 2011
Tonight I went to turn on the light and i felt a static shock, then the light just started blinking and the fan would not respond. The light on the switch is just going up and down? Is this a hazard? What...
You posted under Maestro fan-light dimer, but don't say what type of wall device this is.
It sounds like electronic switch.
1) Surge might have burned out device electronics.
Turn off circuit breaker and see if device resets itself.
2) Lutron has tech support number
1.888.LUTRON1
(588-7661)
8-8 eastern standard time
3) Help identifying product for ordering online replacement if needed:
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroIRDimmer/Pages/Models.aspx
4) Add a comment for more free help.
5) Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Hello, I just installed the Maestro Fan/Light switch (MA-LFQHW) to my cieling fan/light. The fan works perfectly however, the light after a moment or two will start to pulse (dim) then return to normal....
Thank you for including the Manufacturer, Model and Model number
Lutron makes a long list of products.
I found the product manual at Lutron: and am looking at the instructions
http://www.lutron.com/TechnicalDocumentLibrary/033100b.pdf
The Lutron device replaces an ordinary single pole switch.
It is not made to control compact florescent bulbs, just incandescent bulbs.
The switch has to have a ground wire.
Lutron tech assistance 1-800-523-9466 (included just in case I cannot find the trouble)
Troubleshooting in manual: They mention 'upper LED on wall control cycle rapidly.'
The solution is to check wiring, which we will review.
The fan and lights are supposed to be on high (this means your pull chain controls located on fan)
Let's review the wiring.
The switch wires connect to either brass screw.
The switch wires are usually black. Let's say they are black.
One of the black switch wires travels to fan in a cable.
This cable has 2 wires: a black and white.
This cable goes to fan.
The black wire carries power to the fan.
The power wire, or Hot wire from switch connects to the Module-black wire.
The Module-white wire connects to the Neutrals (which are white and usually twisted together and covered with a wire nut).
So all your Neutrals are joined together and covered with wire nut.
The Module-red wire connects to light-wire
The Module-yellow wire connects to fan-wire.
I'm looking at this wiring and it seems so straightforward, I can't find a problem.
According to the troubleshoot, the fan could NOT work properly if the wires were reversed at the Module.
The switch wires connect to either terminals, so there's no confusion there.
1) Unless you forgot the ground wire, or 2) you're using compact florescent bulbs, or 3) the light is not on high, I can't see where the problem is.
I suggest you call the Lutron tech support number.
They may suggest a circuit analyzer, for example a small voltage ground fault in the line might affect their device.
In any case, I want to know how this turns out because I specialize in electrical devices.
Add a comment and keep me updated.
Nov 05, 2010 | Lutron Electrical Supplies
I went to replace the Lutron Skylark dimmer with the Maestro today and found 3 black wires in the box, 2 were bundled and connected to one of the dimmers black wires and the other 1 was connected to the...
The 2 wires that are tied to each other is most likey your hot lead from the panel , the other goes to the light.Tie 1 blk dimmer wire to the 2 wires together and the other blk dimmer wire to the single in the back.Also Maestro dimmers have a small kill switch check to see that it is not off.If you work with hot leads remember don't cross your heart ( wires in both hands current passes through the body)
Aug 31, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Lustro Maestro MA-LFQHW-WH Fan/Light Dimmer
something is messed up for sure... two solutions.... disconnect outlet and cap wires.. or open up both boxes and see where / how they they wired the outlet into the fan/ light control and disconnect it there and then pick up power for the outlet from the black /white wires BEFORE the dimmer control
Aug 19, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Jul 24, 2009 | Hunter 28486 Ceiling Fan
Controller (s) not working
Someone used the pull chain on both units. Whenever you install a remote or wall-mounted dimmer, it's always best to cut the chains short (after setting the fan to high) to prevent someone who doesn't know any better from using them.
Download the installation sheets here:
http://www.lutron.com/cms400/PageBuyNow.aspx?id=16977&mn=1815
May 15, 2009 | Maestro Fan/light Dimmer Ma-lfqhw-wh...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hunter 21871 56'' Ergonomic Brushed Nickel Ceiling Fan Logo
590 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
