Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
CRAFTSMAN 1/2 HP OPENER
I RECENTLY INSTALLED A DRIVE GEAR KIT IN MY CRAFTSMAN 1/2 HP OPENER.AFTER INSTALLING THE KIT THE DOOR ONLY OPENED APPROX 2FT.THEN CLOSED IMMEDIATLEY.THE MOTOR RUNS THE SAME CYCLE EVEN WHEN THE CHAIN IS DISCONNECTED.I ADJUSTED THE UP FORCE KNOB,NO CHANGE,I ADJUSTED THE UP TRAVEL KNOB TO THE FULLEST STILL NO CHANGE,IS IT POSIBLY THE LIMIT SWITCH.?
  • 1 more comment
  • lostsoul544 Feb 10, 2009
    yes the door was unplugged.after reassembly of the unit after installing gear kit the door was down and the inner track guide was in the down position when the chain was hooked up
  • temkim13 Feb 11, 2009
    The original problem description is almost identical to my situation except my door tries to go down first, then up and stops with the door 1' off the ground.
    I have adjusted the up and down limit controls, as well as the up and down weight control. The center contact (the traveller) doesn't even come close to touching the other contacts before stopping.
    I have tried to run the motor with the chain off, the chain on with the door disconnected and several other combinations of conditions. No matter what variable changed the operation was the same.
    Any ideas?
  • Doorguy27
    Doorguy27 May 11, 2010
    What postion was the chain in when you installed it? Down? did you unplug the opener when you changed it?
  • 30 Answers
Ok well the best advise I can give you is to open up your opener case should be a 1/4 nut driver or a Philips head screw driver. Make sure to unplug it first. Once the case is off, find a reqtangle black box with three white plastic screws they are what controls the limits. Chances are they got knocked off wheny ou were putting in the gear. check to make sure the wires are hooked up and find the placement of the limits make sure they can touch each other. Little tip I do for my customs is get a piece of sand paper and rub it agaist the metal contacts for the limits only. (after time lift master openers bind up a film and dont stop where they supposed to.) If your still not sure how the limits work plus in the opener and run it make sure not to put your hands inside the opener and nothing esle is in the way. Then adjest the limits as needed. That should take care of you if not go ahead and make another post ill check back with you.
Posted on Feb 10, 2009
Don't know Mod. No. lost installation manual, approx. 5 yrs. old Need installation manual.
About 496,000 results (0.43 seconds) Search Results
    [PDF]GARAGE DOOR OPENER Model 3265 1/2 HP ... - LiftMaster
    www.liftmaster.com/.../en.../tucmanuals/114a3044.pdf Chamberlain GroupFasten the manual near the garage door after installation. .... This garage door openerhas been designed and tested to offer safe service provided it is installed, ...
    Manuals Download Craftsman Garage Door Opener Model ...
    www.craftsman.com/search=manuals%20download%20crafts...
    CraftsmanCraftsman has the best selection of Garage Door Openers in stock. Get the Garage Door Openers you want from the brands you love today at Craftsman.
    Craftsman 1/2 HP Chain Drive Garage Door Opener - Sears
    www.craftsman.com > ... > Garage Door Openers
    Craftsman1/2 hp Chain Drive Garage Door Opener Opens by Remote, Inside and from Car Enjoy a great end to every day by ... Owners manual - English (Warranty).
    Free Craftsman Garage Door Opener User Manuals ...
Feb 03, 2016 | Building Materials
How much is gear kit for 1/2 #41A2817?
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
Feb 04, 2015 | liftmaster Garage Door 1/2 Hp
Craftsman Door Opener Model #139 53975SRT1 1/2 HP will not open the garage door. It will close it. And if it's on the way down and I hit enter, it will open mid stream. But, if it's closed, an
Two things. Check for a broken door spring. If okay, remove the cover from the motor housing and check for a bad drive gear. This is a white nylon gear just in front of the motor. If it is going bad it should be obvious.
Jul 05, 2012 | Sears Craftsman LiftMaster Chamberlain...
Steelcraft garage door opener opened but will not close. Motor hums but door does not move.
Ensure proper installation. Ensure gears in main control head box are not worn out, The main drive flat gear is plastic in a lot of these openers. Replace main gear unit are rebuild it.
Apr 24, 2011 | Craftsman 34 Hp Garage Door Opener Chain...
Garage door opener won't open or close door
The drive gear is stripped. Remove the cover and you can see it just in front of the motor. It is white nylon and the part number is 41A2817. Available from Sears or any good door opener service company. It will come with instructions.
Jun 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Needs proper adjusment procedures
Check if your garage door is properly balanced. Pull the red handle to release the door and manually open it. It should stay up when opened all the way. Next, pull the door down to waist level. It should stay there. If not, the lift springs need adjustment, and that may be why the opener keeps reversing.
May 06, 2009 | Office Equipment & Supplies
Garage door opener will not work after gear replacement
From your description it sounds like you forgot to plug in the RPM sensor.
Mar 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
CRAFTMAN 1/2 HP OPENER
You say it only opens two feet?? Then closes?? If I may if you a little bit more costly option. Dont replace the gears. They used to be really good 8 years ago but the way they make the gears now there too soft and often strip out much faster. I would suggest that you do what we call a motor head change out. Take off your old chain drive motor head and buy a new one. Pretty simple. Two things though one always make sure you put the new one in with the door down. And the traveler in the down position ( The traveler is the metal thing hooked up to the chain) but far and your gear that you have it sounds to me that you dont have the gears close enough.. but 100 percent on that but a door should never close on it own. It's not safe.
Feb 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman GDO Will not close
readjust the sensor controls on the side of the unit
Dec 28, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
260 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
