Question about Reddy R60A Utility Heater
Will not start
I don't know why. is there a possibility that the karosene could be bad?
    President:
  • 1,922 Answers
If it has spark and your sure of that, check for water/condensation in fuel tank,you could even have algae growing,yes (algae) in fuels and they will plug the fuel line,filter,nozzle,etc.
Posted on Aug 27, 2009
Says open and wont play dvd
what bran and what is it doing? With out knowing that it's kind of hard too answer,but I am going to try.
It sound like an intermittent problem meaning the power is starting and stopping possible bad capacitors.Once they have a load on the they don't hold a charge they are braking down. you can email me and let me know and I will look a little harder
Mar 21, 2012 | Audio Players & Recorders
Van dont stay running
I don't know what brand of vehicle you have, but I would suspect a bad crankshaft sensor or camshaft sensor. Could possibly be a PCM if both of those are good.
Feb 09, 2012 | Cars & Trucks
When pluged in the On/Standby LED will light. When pressing power the On/Standby LED with flash then go solid but nothing apears on the display. I can select what speakrs to use (A or B). All the LED's...
Most likely the unit does not receive power from main transformer. Possible several reasons:
- bad power transformer
- bad main internal fuse 7-8amp. Bad fuse most likely because of one of the channel is blown and shorts the power, so before installing new fuse good idea to check all channels by meter or at least visually for burned parts
- bad power relay
- bad connection, cracked soldering joints
Jul 18, 2011 | Denon AVR-1602 Receiver
Heater will not ignite when plugged in fan will run it trys to light i think its not getting any fuel to light when fan stops heater shows E 1 on the gauge
The heater has a photocell & control board. The safety system is not allowing the heater to run because ALL systems are not functioning properly. The control board shuts the heater down after 5 seconds if the system is not operating at 100%. Most of the time the problem is a simple adjustment, but don't adjust anything without knowing EXACTLY what you are doing.
Suggestion- If you are going to do a DIY repair then send ReddyParts.com an email, request troubleshooting tips for the HSI type heater. Be sure to send correct model of your heater. Without the correct model you may not get a reply.
May 14, 2011 | Reddy Karosene / Desel Forced Air Heater...
I need a new ignitor for my Dyna Glo Pro heater Model RMC-KFA 75TDGP-01
Please call me at 866-883-9312. I have an ignitor in stock that will work for you. The price is $58.99 + $9.75 for shipping.
Thanks Bill
Jan 24, 2011 | Reddy Karosene / Desel Forced Air Heater...
Throw an error code c2 igntion problem
You don't give your model, so I can only assume that you have one of the TA Models.
C2=high voltage.
Read this document
Nov 28, 2010 | Reddy Karosene / Desel Forced Air Heater...
My coleman karosene heater won't work
Hi
Change the sparkplug with the same heat range.Clean the air filter and the gas filter.Change the gas from the gas tank.Disassembly the carb and clean it.Start the engine.
best regards savumihai71
Dec 22, 2008 | Coleman Powermate Premium Plus 6250W...
Reddy R60A Utility Heater Logo
160 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
