Zanussi ZI918 / 12K Bottom Freezer Refrigerator Logo
mick brophy Posted on Feb 13, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a zanussi zi 918\12k fridge freezer. the fridge is warm and the freezer is not working 100%. any ideas?
It has been defrosted. it seems to be working constantly
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Feb 13, 2013
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
309121
Points
2196
You more than likely have a bad relay or capacitor. Hopefully it is not the compressor. You may want to consider replacing it if is more than 10-12 years old. The other possibility is there is a leak in the freon.
Testimonial: "many thanks. yeah it seems there is a leak in the freon. the unit is 10yrs old so had to get a new one...sadly. Thanks again."
5 Related Answers
Anonymous
  • Posted on Aug 30, 2008
SOURCE: The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Anonymous
  • 237 Answers
  • Posted on Jan 14, 2007
SOURCE: Fridge is warm, freezer is cold!
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves no working. Good job trouble shooting!
Anonymous
  • 4889 Answers
  • Posted on Oct 09, 2007
SOURCE: Zanussi fridge freezer - fridge not working
The defrost cycle is not happening like it should, that's what causes the block of ice (and poor air flow). If you have all that defrosted look at the defrost bi-metal, it usually is a small round disk with a couple wires coming out of it and it's clipped on the coils. When it's cold enough, it passes electricity to the heat elements, when it gets hot enough it "opens" and kills power to the heat elements. If that is bad (swollen cracked or bloated) and not passing electricity to the elements that's the problem. Another item would be the defrost timer itself, if it doesn't work (no clock motor turning) then it will never go into defrost. And the last and usually least expected failure would be the heat element themselves not working
A
Anonymous
  • Posted on Oct 07, 2008
SOURCE: fridge doesn't work but freezer does
i have had the same problem, it was the fan which needed to be replaced.
woodchuck789
Charles T Nevin
  • 4070 Answers
  • Posted on Aug 24, 2009
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Zanussi fridge freezer not working.
You will need a service call for diagnosis and repair. It could be a faulty thermistor (electronic temperature sensor), or it is low on refrigerant gas and needs a top up. Gas is the most likely reason. Make sure the freezer isn't on an Eco Mode that only deep chills the bottom, and useful if the freezer is nearly empty.
https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+The+fridge+seems+too+cold+and+has+frost+at+the+back
and
https://www.google.com/search?q=Zanussi+integrated+fridge+freezer.+freezer+only+cold+at+bottom
Zanussi ZENB 2925 Fridge Freezer, 10 years old: Freezer working OK but fridge not working. Any Ideas.
look for ice build up behind freezer - defrost cycle transducer or defrost circuit
fan that blows cold air from freezer to fridge - see if it is working or jammed on something put into freezer .
1helpful
Hi, I have Zanussi ZERB 8441 fridge freezer.
Either the heater or thermostat is not working ohm them out to see which one it is
Fridge light on but fridge warm, freezer still working. zanussi built in fridge freezer 3 year old
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Fridge part now working
Hi and welcome to FixYa. I am Kelly.
What your describing is a result of either an automatic defrosting problem or an Air Damper problem.
Here is what you can do to determine if it is a defrost issue or an Air Damper issue.
1. Unplug the unit
2. Empty the freezer section ONLY contents
3. Place a fan blowing into the freezer section for a little over 2 hours. NOTE: This will make a water mess so be prepared.
4. After the manual defrosting session with the fan re-load the freezer contents and plug the unit back in.
5. Check food section temps in about 4 hours.
NORMAL temps you have an automatic defrost problem
WARM temps you have an Air Damper Problem.
Either of the above will require further troubleshooting or service. At least you will know where to start or... what to tell a service person.
Thanks for using FixYa.
Kelly
1helpful
Zanussi fridge compartment has stopped cooling but freezer is ok
OR.
Zanussi Z87 problem
my fridege needed defrosting for a couple of days maybe this is the problem with yours.
3helpful
Zanussi zk73/46ef freezer working fridge is warm
if this is an air blown cabinet defrost it for 48hrs leave the doors open then try it. hope this helps
1helpful
Top Zanussi Refrigerators Experts
ZJ Limited
ZJ Limited
vince
Johnny 1000
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
