Question about Canon imageRUNNER 2870 Copier
Load Staples in a Canon ImageRunner 2200
Does anyone know how to load staples in the Canon ImageRunner 2200? Thanks!
  • 23 Answers
First step, have staple cartridge on hand, type J1 for the iR2200.
Open the front cover of the finisher, which is the door directly below the control panel, which opens from left to right.
There's a handle to grab on the front right corner where the paper comes out, pull it out all the way.
This will expose that module's back right corner where the green staple holder handle is.
With thumb and forefinger, reach in, take hold and lift up and pull out the staple case by its green tab.
You'll see "push" on the sides of the staple case, squeeze thumb and forefinger, one on each "push" sign, and the top will spring up, which is the clear plastic case through which you can see a large spring. Pull out the staple cartridge from the back, under the green tab.
Put the new cartridge in with the orange seal tape hanging out the back.
Press down on the spring-loaded case until it clicks into place again.
Remove the orange seal tab by pulling straight back, then down, not at an angle, as you don't want it to break, just to come off.
Holding it by the green tab, lower the staple case back into the finisher until it settles snugly into place.
Hope that helps!
Posted on Apr 10, 2009
Canon Image Runner 4570 saying load staples when staples have been replaced
yes, there is in additional function then Common setting then finisher or staples you swicth to off
Mar 06, 2013 | Canon imageRUNNER 4570 Copier
Where do you load staples into a Canon imageRunner 3245i?
That would depend on the model of finisher you have attached to the machine. If it is a larger finisher attached to the side of the machine open the Sorters front cover and the inner door should have a sticker with instructions. If you have an internal finisher it can be the same concept open cover and load the staples as show on the cover. There is also another internal finisher where a gray handle is pulled to slide the finisher out and the staples load into the upper rear area of the finisher.
Mar 05, 2012 | Canon Office Equipment & Supplies
I have been trying to load the stapler but when I put the cartrage back into the unit it starts making a weird noise and the the screen still shows load staples so I do not know whether I am doing...
Remove the stapler cartridge and look on the clear plastic part of the cartridge. Do you see the arrow pointing towards the puncher side of the cartridge. The arrow of the replacement staples should line up. I've had customers put the staples in upside down before. The only problem is that you then have to take the staple cartridge apart to remove these staples and reuse them. . You just have to release the 4 clips at the bottom and carefully remove the piece. Be careful of the black arm that hangs down when the cartridge is held in the up position. When replacing the bottom back on, the orientation of this arm is important ( upside down or right side up) . This tells the copier that the staples are out. Hope this helps.
Jan 13, 2011 | Canon imageRUNNER 5570 Copier
I wasn't able to pull all of the white tape surrounding the staples out when I loaded the staples. Now, the copier is saying that we need to load staples. How can I open the holder to remove the tape?
You have to be careful. Remove the bottom of the cartridge by releasing the four clips that hold it on. Make sure you put the little lever looking part in correctly when you reassemble. This is how the finisher determines the out of staples indication. Remove the staples and put them back in with the arrow aligning with the clear arrow on the cartridge.
Oct 29, 2010 | Canon imageRUNNER 5570 Copier
Canon Imagerunner 3035. refilled staples, but copier thinks empty
frst: did you set the staples according to the instructions?
second: try the few times remove and insert staple cartridge in and out, until you heare the loading clicks.
third: check the staple holder for damadges or residuals of staples.
Jul 31, 2010 | Canon imageRUNNER 3035 Black and White...
Need instructions to load staples in Canon imagerunner 2270
pull the finisher out
you will see the staple in the end of it
pull up the staple cartridge using the green handle
then insert the new one
Apr 06, 2010 | Canon imageRUNNER 2270 Copier
How to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Nov 23, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Where to load staples
If you have a internal finnisher,you open the front cover of the finnisher,remove the stapler cartrigde with it's green handel.Remove the paper cover of the previous cartridge.Insert the new staplers in the possition of the arrows.Remove red plastic.Reinsert cartridge back into machine.
Nov 19, 2008 | Canon imageRUNNER 2870 Copier
Canon imageRUNNER 2870 Copier Logo
2,454 people viewed this question
old marine
old marine
