Question about Fujitsu LifeBookS6120 Notebook
Fujitsu LifeBook N6200 monitor went blank
I have a Fujitsu lifebook N6200. When I turn on, the hard disk turn on for a while and it is when blank (black screen).
Can't perform system recovery on Fujitsu LifeBook UH 552
If you started a system restore from your CD, all of your data is gone and you must rely on your backups. Usually if you press F8 just before it tries to boot, you may be able to use the recovery partition on the hdd.
Apr 09, 2014 | Fujitsu LifeBook AH531
I have a fujitsu lifebook n6410 notebook that I forgot the hard drive password cant use computer without now help
These WEB sites may help remove the hard disk password.
HARD DRIVE PASSWORD UNLOCKING - Purchase
http://www.hddunlock.com/purchase/ A-FF HDD Unlock Wizard (HDD Password unlocking - Free)
http://www.hddunlock.com/download/
Apr 03, 2013 | Fujitsu LifeBook N6410 Notebook
My Lifebook C2310 has a blank screen. How can I fix the problem?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 21, 2013 | Fujitsu cp189608-01 - Lifebook C2310...
The screen on my Fujitsu Notebook N6000 just went blank
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 06, 2012 | Fujitsu Siemens Fujitsu LifeBook N6000...
Fujitsu Lifebook does not boot up
Have you tried draining the static on your computer?
Turn off the computer
remove the battery and adapter
press and hold the power button for 1 minute
plugged back in the adapter and battery
turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
I suspect possible LCD issue.
May 21, 2010 | Fujitsu LifeBook A6010 Notebook
Hard drive info for Fujitsu T4210
Better late than never. See http://simshsia.wordpress.com/2008/07/15/disassembly-of-the-fujitsu-lifebook-t4200-series-tablet-pc/
I hope this helps. Should you have the original system restore disk ( or copy ), kindly get in touch.
Nov 03, 2009 | Fujitsu Siemens LifeBook T4210 Notebook
Will not read jump drives and SD cardsover 2GB
I'm not sure what model of notebook you have. However if your computer is not reading the jump drives, maybe you need to allow microsoft updates so just released drivers for various ports could be update.
Aug 17, 2009 | Fujitsu Siemens LifeBook N6200 Notebook
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Fujitsu Lifebook N3010 boot error
Do you have the original Driver and Application (DAR) CD? If so change your BIOS setting to boot from CD first and boot from the DAR. This will take you to the backup partition DICE (Disk Image Special Addition) on your hard drive. This will allow you to restore your system to the original drive image configuration. You will loose all your data!!!!!!!
Mar 10, 2009 | Fujitsu LifeBook N3010 Notebook
I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Dec 07, 2008 | Fujitsu LifeBook E8010 Notebook
Fujitsu LifeBookS6120 Notebook Logo
403 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
