Question about Dryers
Stops running during cycle
Start the drying cycle and within 2 min. the dryer stops running. Is this a timer problem? I have checked for clogged vents and there are none.
    President:
  • 1,902 Answers
Replace the timer and all will work ok. The timer is stuck for some reason, you may be able to clean it out if there is any debris but you are best off just replacing it. 25 dollar or so part
Posted on Feb 09, 2009
Kenmore Elite Model 11087731700, the timer decreases during cycle and stops before items are dry.
check the venting for your machine, the normal problem for clothes that don't completely dry is clogged vents , if your vent is clear and free from any buildup , you could have a bad thermostat which shuts the heat down too early as the drying cycle progresses
Jun 21, 2011 | Kenmore Dryers
Takes 4 ever to dry clothes. Will run & run when on auto dry.
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Jan 09, 2011 | Amana NDE5800AY Electric Dryer
Runs for 15-20 min and shuts off when restarted it will do the same
Clogged Vent
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
This is a free answer, Please rate me.
Oct 10, 2010 | Roper REX4634KQ Electric Dryer
My maytag neptune dryer is taking twice as long to dry cloths. i've had it 5 years & it's gas.
Clogged Vent
Cycling thermostat
Oct 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
MY KENMORE DRYER IS TUMBLEING BUT IT WONT DRY M CLOTHS
Clogged Vent
Cycling thermostat
Oct 04, 2010 | Kenmore 73952 Gas Dryer
My kenmore dryer heat element goes on and off. The clothes take hours to dry.
It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Dec 31, 2009 | Kenmore Dryers
Tumble dryer will not dry
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
Aug 19, 2009 | Dryers
Dryer has to be run repeatedly to complete one load. shuts off before clothes are dry. is this a sensor issue, and how is it replaced?
Aug 05, 2009 | Dryers
Kenmore 11070702990 Gas Dryer - Timer does not work
May 09, 2009 | Kenmore 60172 Electric Commercial Dryer
Drying timer on auto dry
I called LG...they said to unplug the dryer for 5 min. to reset the timer ...this solved the problem.
They also said not to use dryer sheets during the sensor dry cycle as the coating on the dryer sheets causes the sensor to malfunction as it can't read the humidity level in the dryer.
Dec 28, 2008 | LG Dryers
Dryers Logo
106 people viewed this question
Top Dryers Experts
