Question about Kenwood KDC-1011S
Loose plug, & adjustments
I just bought a used 1011s, & found out it has a short in the plug. I move it & loose anywhere from 1 speaker, to complete power. is there an easy fix for this problem?
Also can anyone help with how to adjust the settings? Front, back, left, right,bass, treble& so on. Thank you for any & all help.
    Problem Solver:
  • 11 Answers
There is a button that says aud on it and you can do it from there!
Posted on Jul 30, 2009
I have a rockford fosgate ounch 325.1 (2004). I recently helped my parents move and took the sub and its sealed enclosure out of my 1994 Ford Explorer. The sub and amp worked until the move. After I...
it sounds like you have a short someplace. also, if you have a multimeter, check the voltage coming out of the speaker terminals of the amplifier. if the voltage is higher than 4 or 5 volts, the amp is probably bad.
Jan 10, 2011 | Car Audio & Video
Hi! Brand new unit - bought 1.5 years ago - never opened the box (such an idiot I am) I have a use for it not but it doesn't work. Press power on - I hear a click an dthat's it - nothing lits up. I uppan -...
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
May 30, 2010 | Yamaha RX-V363 Receiver
Sub woofer got weak
If there is an adjustment, turn up the subwoofer volume. After you started shaking the house somebody may have adjusted it for you.
Check your computer control panels volume too, cause they may have a subwoofer volume there too.
If there is an equalizer (software) then make sure the low frequencies are set properly (middle or above). Check for this in your computer audio control panels.
If there is no adjustment anywhere, take it back, 'cause it is busted. If it is too late to take it back, sent it to logitech for repair under warranty. If it is too late for that, go buy a new one.
--Dave
Feb 07, 2010 | Logitech X-540 Computer Speakers
New chain gets loose fast.
A worn set of sprockets will kill a a new chain in short order - particularly a worn countershaft sprocket.
The issue is that, with a worn sprocket, all the force is on only one roller at a time.
Overtightening a chain will kill it in short order as well.
The issue is that chain tension changes as your rear wheel goes up and down (the swingarm pivot and countershaft sprocket are not concentric so the distance between the sprockets changes as the wheel position changes. Typically, you want to be able to move the midsection of the chain up and down 1.5" to 1" after adjustment.
If the rear wheel is out of line, that will also kill a chain, but it will take longer - and your bike will not handle that great.
Finally, are you [i]sure[/i] it's the chain? You may have simply failed to tighten the axle nut sufficiently and the axle has moved forward (and is probably angled out of line as well)
Dec 14, 2009 | Honda CRF 100 F Motorcycles
Loose mounting brackets on JBL Control 23 Speakers
Remove the JBL badge on the front grill, insert the supplied hex wrench and turn counter-clockwise until it's loose enough to adjust the speaker, the turn the hex wrench clockwise to tighten it. If you don't have the hex wrench, you can use a long allen wrench.
http://www.jblpro.com/catalog/support/getfile.aspx?doctype=3&docid=1372
Oct 24, 2009 | JBL Control 23 Speaker
Harman-Kardon HK695-01 Speakers Connection Quesion
According to the manual
http://tv.manualsonline.com/mdownloads/14ae515f-03bc-a2d4-8940-672bfa19f017.pdf
leave the black connector unconnected.
Hope that helps.
Oct 02, 2009 | Harman Kardon HK695 Computer Speakers
Wires to radio harness
red is power black ground yellow power when key is on  blue with white strip is remote wire only need if you have system
Jul 04, 2009 | Kenwood KDC-1011S
What is the red wire and blue/white wire?
red is the remote wire, white is a speaker and blue is the powered antennae wire!!
Apr 30, 2009 | Kenwood KDC-1011S
Getting humming sound from all speakers. BA 700569 MicroMedia
It sounds more like the power supply is at fault (a filter capacitor dried up), but it'll take an oscilloscope to verify that - take it to a TV repair shop (if you can find one) or find a ham radio operator who still has test equipment. (If it happens even from an iPod, it'll be easy to troubleshoot, since the person doing it can use any audio source to cause the problem.)
Feb 09, 2009 | Boston Acoustics MicroMedia Computer...
Ix406 front speaker distortion at all frequencies
Repair- "No". But make sure the power line is not running next to the RF speaker line nor the line in to amp more then a few inches to a foot. Often can cause distortion regardless.
Lazlowww
Oct 28, 2008 | Kicker Car Audio & Video
Kenwood KDC-1011S Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
