Question about Sony KP-57HW40 57" Rear Projection Television
Red and green curved lines when the screen is dark
My SONY KP-57HW40 has red and green curved lines showing when the screen is showing a dark scene. I know a solution has been discussed before, but I cannot find the answer. Any help would be appreciated.
Jagperson
  • 42 Answers
Your screen controlls are up too high
Remove the front of the tv and look for the focus block
*** with all things electronic be careful and only use one hand to adjust
turn the color all the way off and then adjust the screen controls so you don't any lines (retrace)
do not touch the focus controls you will make the picture blury
make the picture loiok black and white the best you can
You may have a bad crt or two
if this keeps acureing or you can't get a good greyscale
Posted on Feb 09, 2009
  • 6,784 Answers
Your convergence board is going out. this will have to be replaced. i would take a look at the main logic board as well. it could have minor point breakage.
Red horizontal slightly curved lines on dark scenes. Sony KIP-57WS500 Rear Projection TV 57".
u need to adjust the focus screen , this is located right under the picture tube , u need to take the front speaker grill off , look close to the botton of this grill and u would see a small cover that is covering the screw , remove ths screw and pull hard
Dec 14, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
I BOUGHT A KP-57HW40 SONY AND ALL I CAN SEE IS A
Try this....
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
These sets have weak picture tubes, this may buy you some time. It is not worth changing the tubes in the set. The cost would be more then its worth. Try these adjustments until it completely dies. I have the same set.
Apr 21, 2009 | Sony KP-51WS500 51" Rear Projection...
Thin red horizontal lines appear when viewing a dark background
Look around this sight the answer is explained here. you hace to take off the front speaker cover and a small panal undder it. you will find six knobs on a small panal. use these to adjust the settings fotr the power and they will remove the lines. You will need to have the tv on and I would sugest a normal size phillips head screwdriver not a power tool.
Jul 26, 2008 | Sony KP-51WS510 51" Rear Projection...
Curved blue lines on screen.
You have a completely different problem. The screen voltage for the blue picture tube is slightly too high on your set. This will put fine lines in the background of the picture, called retrace lines. This is very common and easy to correct. Remove the front speaker cover and the access panel behind it. Look inside and you will see a black box with six controls, each control having a little white glue on it. This is the Focus/Screen block. Three controls are labeled Focus and three are labeled Screen. The screen control in the center is for green but I am not sure if the screen control on the left or right is for blue for your model. With the TV on, set it to VIDEO 1 but do not connect anything to the VIDEO 1 jacks. This will produce a pure dark picture, showing any faint lines in the background. Choose one of the screen controls and increase (turn clockwise) it slightly. If the blue lines do not get brighter it means you are turning the red screen control, so put it back where it was and choose the other screen control. When you find the blue screen control, decrease (turn counter-clockwise) it until just when the blue lines are gone. If you want you can check that the red and green screen controls are set to just below the point where their faint lines are visible. When done, replace the panels and your picture will be back to perfect.
Apr 11, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-57HW40 57 in. Green Circles
well just remember the in the electrical industry its not 100 percent all of the time. you might just want to buy a new one.
Apr 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Kp-57hw40 screen goes bright red or green then powers off
http://esupport.sony.com/perl/news-item.pl?news_id=24
heres a recall of sony hope it helps.
Dec 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 Error Codes 6 & 8
ITS PROBABLY THE RED PICTURE TUB (CRT). IT LOOKS EASY TO INSTALL, BUT YOU NEED TO MAKE ADJUSTMENTS TO THE SCREEN ONCE IT IS INSTALLED. THE PART IS $3OO. TRY TO FIND SOMEONE TO INSTALL IT FOR $150 OR LESS. HERE IS A WEBSITE TO HELP YOU MAKE ADJUSTMENT IN THE FUTURE ON YOU OWN.
PRIDAH
Nov 10, 2007 | Sony KP-57WS500 57" Rear Projection...
Sony tv KP-57XBR10W
Correct ! One set is for RGB focus and the other set is for
RGB screen voltage............................T.
Oct 05, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
182 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
