Question about Philips GoGear SA3245/37 Digital Media Player
Shuts off when turned on
I just got the mp3 player brand new and now when i turn it on it says upgrading with a bar under it. it goes one square and then shuts off and it started doing that after the first time i tried to put music on it using windows media player.
can you use windows media player gor it or does it have to be the software?
  • 8,596 Answers
You can definitely use Windows Media Player - in fact, it is the reccomended program.
From your description, it sounds like you might have turned your mp3 player on before fully charging it. Let it charge for 3-4 hours before adding music or doing anything else. The "updating" message will eventually go away as long as you don't unplug the player from the computer before it finishes updating. If you do unplug the player from the PC while it is updating, you will effectively destroy your GoGear.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
How do you turn off the samsung yp-z5 mp3 player?
Press and hold the bottom bar of the square ridged around the central button. This is the bar you press to play/pause and start up the player. It should have a power button symbol on it.
Apr 01, 2011 | Samsung YP-Z5 MP3 Player
My sansa wont turn on
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
this is their instructions not mine, but i hope this helps you.
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Display on mp3 player shows "Magnavox" and then shuts off
MP3 players are so cheap nowadays, so Id recommend getting a new one instead.
Aug 09, 2009 | Toshiba gigabeat MES60VK Digital Media...
Shutsoff, stays off problem...
Get the updated verison of the Philips Device Manager from Philips website, and then click on the Update button once you have installed the new Device Manager.
Several things to be wary of:
* a Philips player ending in "/02" is designed for use outside of the United States
* the SA5125 is incompatible with Windows Vista and Windows Media Player 11 without a firmware upgrade
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
Shuts off when upgrading
You have to get the latest version of the Philips Device Manager for your model, and then run the "Update" function in the device manager.
Jan 26, 2009 | Philips GoGear HDD075/17 MP3 Player
Screen shuts off when turned on
Check the battery, is it fully charged, if so then how old is it?? I once had a maybe 1yr. and a half one that did that ll the time. R u sure you are pressing the right button or pressing only 1 button when u do it! srry if my answers dont work! I tried hope it works out!
WHat Is File System Err??
try downloading the cd driver or setup driver it came with.
then look through it for a program with a rocket ship icon.
open it.
click firmware upgrade, plug your mp3 player into the computer, select the newest firmware upgrade(it only shows new or current ones), open it, then click start upgrade and it should be fixed.
Jan 11, 2009 | Nextar MA933A MP3 Player
Cant turn on 2 brand new fully charged music on
you need to upgrade your usb port go on the samsung website it will tell u how
Dec 25, 2008 | Samsung YP-U3 MP3 Player
What does "Refreshing Database" mean?
You will need to upgrade or reinstall the firmware on your MP3 player. You may download the firmware on http://www.sandisk.com/Retail/Default.aspx?CatID=1376. For the manual installation of the firmware upgrade, you may go to this site: http://www.sandisk.com/Retail/Default.aspx?CatID=1449
Oct 12, 2008 | SanDisk Sansa e260 MP3 Player
New SanDisk Sansa m240 MP3 Player
there are 2 usb choices on the sansa m240 one is msc the other is auto detect. msc is for downloading new upgrade software i beleive , because thats the setting sndisk has you set it on to download new upgrade software .it stands for mass storage class .it may need to be on auto detect .
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
Philips GoGear SA3245/37  Digital Media Player Logo
67 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
