Back to:
Tags:
Saeco Easy Espresso Machine
User Feedback wanted: Saeco Vienna & MAgic DeLuxe
By Powe33 - usenet poster
I am trying to narrow down my choices on a home superautomatic
expresso/cappuccino machine based on the advice and counsel of the many
posters to this NG (which I wish to Thank profusely for their help).
I am soliciting both positive and negative comments regarding the above
machines. I am increasing my budget to a max of $900 based upon comments in
the NG but would be happier to spend $500 or less. I need to be convinced
that there would be a dramatic difference to a casual drinker as opposed to
the aficionados out there. I'm sure my wife will feel that the expense of a
high quality machine is too extravagant (if she finds out), given the budget
limitations of a family of five. Your thoughts?...
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Bray
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"JohnH" <
Well, since I started the problem, you know my opinion, but I'll post it
again, partly for completeness and partly because there's a butthead who owns
one of the mail-order companies who posts particularly misleading messages
here.
The Vienna is an adequate machine. It will successfully and consistently
produce drinkable espresso with a single press of a button. It uses the same
"brew group" as the Magic de Luxe; the brew group is the unit that does the
tamping and brewing.
The Magic de Luxe is a much better unit. Properly programmed, it produces
excellent espresso, very consistently.
A manual machine can produce Magic de Luxe quality espresso, but will, in the
hands of an inattentive user, produce dreck that can't even compare to Vienna
espresso. In the hands of an expert, a manual machine is not just used to
create the drink, but to perform the ritual of espresso preparation. For some
people, this hands-on ritual is a very large part of the taste. I find it
more inconvenient, largely because my wife is challenged if it's more than a
button-press.
The Magic de Luxe produces better espresso than the Vienna because more
parameters are under your control, and they're further under your control. I
have mine set to brew a shot at 30gm of water, with roughly 8 gm (maybe 9) of
fairly-finely ground beans. I don't think the Vienna can go down to a 30gm
shot, and doses 7gm of beans. The Magic de Luxe came defaulting to 60 and
120, I believe! (Easy to program though; if you buy one, ask for people's
favorite settings. It will save time and frustration.) The Magic also
remembers multiple settings, and allows easy brewing with another pre-ground
bean (such as decaf.) I haven't used either of these features; I set the
settings for the beans I buy, and I don't drink decaf.
Is the Magic de Luxe worth the almost-double? Probably not, if money is tight
and neither of you will drink espresso straight. If it's always mocha and
latte, the Vienna will probably serve you fine.
If money isn't so tight or if you like it straight, you NEED a Magic de Luxe.
You'll regret it if you don't.
Lastly, about those misleading statements from a purveyor of perfectly fine
goods at excellent prices (and they are fine goods at good prices): there is a
poster here who is fond of saying that the Vienna is a toy because the Magic
de Luxe (and Royal Classic) weigh twice as much. Note that most of Saeco's
machines weigh 2/3 of what the Vienna does (it weighs 14#, most Saeco manual
units weigh 9#.) Also note that the other heftier machines have a warming
tray (a big thick hunk o' metal) and a swivel base (two thick plates of metal
plus bearings), that the Vienna lacks. The brew group is the same, the pump
is probably the same or at least good enough. The power draw and tank size
are the same. I think he's full of it. Let your budget and drinks guide you
instead.
(Although he does have good merchandise and prices.)
--- To reply, remove the spam-protectors (deletethis, ignorethis) from my 'From:' line ---
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on User Feedback wanted: Saeco Vienna & MAgic DeLuxe:
I don't want to Accept this solution
Can you Help with these Coffee and Espresso Makers problems?
Have bought 12 cup replacement wire mesh filters for...
When we make coffie, there is lot of water on the counter...
basket is leaking- there is one black rubber...
So I try to make steam and instead of clean smooth steam,...
The leak comes from under or behind the brew group. When I...
Loading problems.
Repair Service
Find Coffee and Esp. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
