Question about Singer Izek Computerized Sewing Machine
The machine runs backwards instead of foward.
The machine makes a perfect stich backward. When you push the reverse button it runs foward. Can you help?
Thank you Lewis McElfresh
    Sergeant:
    Champion:
  • 239 Answers
Switch cabel connections
Posted on Feb 09, 2009
What is my Janome 415 feeding the fabric backwards? How do I fix it?
You have the reverser in the back stitch setting. When you do an over lock stitch you change the feed direction. It should be a lever. Some have a screw lock to keep it in place.
Aug 19, 2014 | Sewing Machines
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
My friend bought jenome sewing machine. It is working very well except that it only sew in reverse (backwards). Could it be that the reverse button got stuck or is there a setting that needs to be done?
button in centre of stitch length control is probably gummed up and stuck lubricate with penetrating oil and wind stich control backwards and forwards to see if centre knob starts to move. Remove arm top cover and do same to mechanism visible from above
Feb 19, 2014 | Janome Sewing Machines
Buttonhole
Set the machine to button hole and use the "C" foot. The machine sews backwards first. When it reaches the correct length push the reverse button. Then when it has sewn the left side even with the right side push reverse again.
Dec 23, 2013 | Husqvarna Viking 1
When I am sewing it start stiching backwards instead of forwards
it would be a good idea to have the machine checked to see if the
reverse button has gone out.
Jun 11, 2012 | Euro-Pro Sewing Machines
Dogs motor?
Does it have a stitch length dial which ranges from 4 down to 0 and then into negative numbers? If so, the negative numbers will be reverse stitches. Some machines have this functionality and its very happy for doing mending or stitching in awkward places to sew backwards without having to hold the reverse button.
However, if yours is only sewing backwards when stitch length is set to 2, 3 or 4, then its probably a drive problem internally. Don't think your machine has a seperate motor for the feed dogs, probably a gear driven shaft in the free arm.
Dec 06, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Never used, just took it out of box. sews only in reverse. cannot get it to sew foward Please help. Thank you
often there is a button or a hook you have to push or pull out to get the machine to sew in reverse. Check to see if there is something like that that you could pop back into the normal position. Alternately in older models if you bring the stitch length adjuster past 0 it will begin to sew backwards so you could try that too. Good luck!
Sep 22, 2011 | Singer 3116 Simple
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
Dec 13, 2009 | New Home MX-3123 Computerized Sewing...
Singer Izek Computerized Sewing Machine Logo
279 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
