Question about Copystar CS-1820 Copier
Error C6000 - call for service
This happened on our little CFopy Star GS 1820 after we had a power outage for about 24 hours.
    President:
  • Copystar Master
  • 990 Answers
Hello sir; It can be reset the procedure as follow;
1, press and hold down these keys by order, "start', left "#",
2, press "enter".
3, enter 163 then press enter.
4, choice "execute", then press "enter".
5, turn off the power and back on.
Posted on Feb 10, 2009
Stuck in the C6400 Error and cannot get out of it, nor print anything. My printer is a KYOCERA KM-1820. Any assistance would be appreciated.
SIM 163 Reset (only do this one SIM, by doing others you could cause your machine to no longer function. Also see note at bottom.
Entering Simulation Mode
1. Press the system menu/counter key.
2. Select Service setting using the up/down cursor keys.
3. While pressing the start key and the # key, press the enter key. (Maintenance mode is entered.)
4. Select Maintenance mode using the up/down cursor keys.
5. Press the enter key.Enter the maintenance item (163 Resetting fuser problem) number using the up/down keys.
6. Go to step 1 under method below.
Resetting the fusing problem data Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Note: Sometimes in order to do the reset when the machine is in an error state you need to open the top cover (like to replace the toner) and leave it open until you have performed the reset.
Mar 31, 2011 | Kyocera Copystar CS-1820 Black and White...
Kyocera km-1820 error occured call service person c6000
Contents: Broken fusing heater wire
• In fusing warm-up, the time to reach
50 °C/122 °F exceeds 13.5 s, the
time to reach 100 °C/212 °F exceeds
10 s, the time to reach the primary
stabilization exceeds 10 s or the time
to reach the secondary stabilization
exceeds 24 s.
Causes: Poor contact in
the thermistor
connector terminals.
Thermistor installed
incorrectly.
Thermal cutout
triggered.
Heater lamp installed
incorrectly.
Broken heater
lamp wire.
Check procedures/corrective measures: Check the connection of connector YC4 on
the power supply PWB and the continuity
across the connector terminals. Repair or
replace if necessary.
Check and reinstall if necessary.
Check for continuity. If none, replace the
thermal cutout.
heater lamp
Sep 13, 2010 | Kyocera FS-1118MFP Laser Printer
Service code for this printer came up C6000 what
This is a fixing unit error. If you have had a power outage or your power has flickered it maybe able to be reset with out parts. Go to www.gfbm.net and call thier number and they should be able to reset it over the phone at no charge.
Feb 18, 2010 | Kyocera Mita KM-5035 Printer
Service code c 6000 comes up what do we do? 314 308 5296
fuser error..nothing you can do but replace the fuser unit..
Jan 25, 2010 | Kyocera Copystar CS-1820 Black and White...
What do you mean by error c6000 in KM4050?
Error code c-6000 means fuser error. It would be best to replace the fuser unit as a complete assembly, but sometimes just the thermostat can be replaced, which would be cheaper. Either way, an authorized Kyocera dealer should have these parts.
Nov 12, 2009 | Kyocera Copystar CS-1820 Black and White...
I am getting an error C6000 on my Kyocera KM-1820 after we had a power outage. I can't seem to get it to turn off. What do I need to do in order to get the copier to work again and for it not to have the...
Go into the service mode ( 10871087 ) then enter 163 then hit the start button. This clears the C6000 (heater error) and if it is a false code due to a power outage, it will clear the code and resume normal operation. If the code comes back, you likely have a bad heater lamp or thermal fuse or thermistor.
Aug 19, 2009 | Kyocera Copystar CS-1820 Black and White...
C6000 error code
Hi
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 09, 2009 | Kyocera Copystar CS-1820 Black and White...
KYOCERA copystar CS-1820 ERROR C6000
Your problem is heat related, or the lack of heating at least. one of 2 things went wrong here... either the fuser unit overheated causing the thermal fuse (aka the thermostat) to blow, or the heating lamp in the fuser unit is blown. Basically the 6000 code is displayed when your machine fails to reach the correct temparature at a specific time. Unfortunately you will have to call a service person to check which to of the mentioned components are at fault and to replace that component for you. After replacing, the component the code will still be displayed as a safety measure, so the service representative will need to clear the code via the machine's service mode
Sep 22, 2008 | Kyocera Copystar CS-1820 Black and White...
207 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
