Question about Sony ICF-C318 AM/FM Clock Radio ( White )
Help - I lost the user manual for my Sony Dream Machine C318.
I don't know how to set the time.
What is DST?
And the alarm keeps going off inspite of my turning it off.
Can you help?
This machine is driving me crazy.
  • 4 more comments
  • Ann Cleary Mar 08, 2009
    I can't set time
  • njbobbiegrl Mar 10, 2009
    I can not change the time on the clock. alarm is easy, but 'time' is driving me crazy.
    thanks!
  • Anonymous Mar 17, 2009
    cannot reset DST to the correct time...
  • Susan Johnson Mar 26, 2012
    To set the Dream Machine by Sony Model ICF-C414 ... just hold down the button marked "time" for 2 or 3 seconds, then the Time Zone will say 7.. but I just ignore that and press the time button to get to the day and month and press the button again for time... be sure to set it to am or pm... and just press the time button again it will beep twice and you're done... (be sure to double check Daylight savings time, there's a button for that..) The clock should set itself if the batteries and everything are good...
  • Anonymous Mar 29, 2014
    I tried to take the batterie off but still not working.
  • karen hansen
    karen hansen Mar 15, 2019
    i tried to set the round dream machine clock/cd/radio/and instructions and im frustrated
    President:
  • 2,559 Answers
Here is a link to the manual http://www.docs.sony.com/release/ICFC318.pdf
Please rate this a fixya
Posted on Feb 09, 2009
  • Sparks24 Jul 16, 2011
    Thanks!
    I had the same problem - no idea how to set the time
    Mauries
    Australia
  • Fely Skelly May 26, 2013
    Thanks Randy Hough. I also had the same problem and happy that I get to use it now after reading the link to the manual you shared!
    New Friend:
Press and hold down the clock button until it beeps. The first numbers to come up are the years last two digits, use the -+ buttons to adjust if necessary. Press the clock button once quickly and it brings up two more sets of numbers, these are the month and day. Adjust if necessary then press the clock button once quickly. The next thing that comes up is the time. It is now adjustable with the -+ buttons. The time doesn't flash or anything to tell you that you can set it but you can! Then press the clock button once more to save the time.
Do not allow more than 60 seconds to go by or you will have to start over.
Posted on Sep 05, 2012
  • 1 more comment
  • William Saylor Dec 30, 2012
    Thanks. Electrician changed circuit board / fuse box for the whole house today, and I returned home to find all the numbers blinking at "12:00". Yikes. Lost the manual yolks ago and have to set alarm for morning, but a real pain to have to subtract time-now from real-time future desired alarm time, then add those hours and minutes to 12:00 AM, and repeat process every day until I can set the clock to my wristwatch time. Two questions: (1) You said that after the date is set, one can set the time, and "the time doesn't flash or anything to tell you that you can set it but you can!" When I followed your directions, the numbers Did Flash, so I touched clock button once more, thinking I hadn't followed your suggestions, and the time did stop flashing; but then the + and - buttons did nothing, and the time was stuck at a non-flashing 12:00 AM. So I hit clock button again, pushed +until the time matched y watch, and then hit clock button again. Then all was well. It took longer than 60 seconds though, but sin I didn't start over again except to set time of day, maybe the month and day are no longer set correctly. (2) I didn't know before tonight the clock allowed you to set month and day and year; but why does it matter to me -- or matter to the clock's functions -- that the clock "knows" what the current date is? When the clock is set, the face plate doesn't read out the date, like my watch does. What am I failing to grasp?
  • holmanandass
    holmanandass Jan 22, 2014
    OMG - thank you, thank you, thank you. I use it as my alarm clock and somehow unplugged it and was pulling out my hair trying to figur out how to reset the time. Thank you for your simple, easy to follow instructions!
  • philomena_li
    philomena_li Feb 15, 2014
    Thanks. I'm so glad that I have found you.
    Brigadier General:
  • 8,619 Answers
Hi!
DST is daylight saving time. When Daylight Savings Time changes take place in the spring and fall each year, there is no need to adjust the clock because the built-in calendar recognizes the dates and automatically makes the proper time adjustments.
For more details and how to adjust these settings see the manual from the link below--
SONY AM/FM Clock
Please rate this solution.
Thanks
Rylee
  • karen hansen
    cd3lp...icf i can't figure out how to set the time???help
How can i set the time on my sony model no icf-c218 dream machine alarm clock
Posted on Feb 10, 2010
  • craigs178 Feb 07, 2011
    Where is the answer to the question?!?
    New Friend:
I have sony ifcc414, and tried to figure out how to change the 4 minutes earlier. it is four minutes faster. How do I change it. It's confusing when I pressed the button on the clock knob. I didn't know what the are the numbers. I lost the manual book. Can someone help me out here. I m on California, PST. thanks
Posted on Mar 09, 2014
SOURCE:
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
How do I get the alarm to work? I set the alarm for 5am, it did not go off. The sound is off, I have the volume to the highest point, nothing comes out.
Make sure it's on the correct am/pm. Also, make sure that it's not set to radio, or auxiliary, or anything. If it's still not working, I would try to return it.
Mar 09, 2015 | Sony ICF-C318 Dream Machine Alarm Clock...
Cannot reset dst to correct time. setting time is driving me crazy
Press and hold DST button for more than 3 seconds while the clock is displayed. A beep sounds and "AUT->OFF" appears on the display to show that automatic DST adjustment is canceled.Then the display returns to the clock.
If you have not manual and you want it can be downloaded:
http://www.docs.sony.com/release/ICFC318_US.pdf
Thanks.
gylacz
Aug 25, 2011 | Sony ICF-C318 AM/FM Clock Radio ( White )
Sony ICF-C318 AM/FM Clock Radio ( White ) Logo
48,855 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
