Question about Dell XPS 420 PC Desktop
Computer isn't working.. with a very annoying long beep.
The lights that flash are 1 and 4, and then sometimes 2 and 3. It switches.
The beeping isn't anything like the codes I found in my manual, it just goes on forever, repeatedly. beepbeepbeepbeepbeep
I've tried un-plugging and then replugging the computer, and then my father took out the memory and put them back in.. problem still persists.
And the monitor doesn't say anything for me that would help..
  • randomranma Feb 09, 2009
    We can't find the culprit..the computer hasn't worked normally yet.
    but we have gotten 1 and 2 flashing lights now.
    Wow. Okay I found the problem..
    just wow.
    I had some things lying on top of my keyboard that prevented it from starting up. Just wow.
    Thanks anyway~
    Sergeant:
    Champion:
  • 275 Answers
Disconnect all the drives connected like hard disk , cd drives or dvd drives and floppy drive and than start the system and if i am not mistaken it should start ... than shut the system again and than connect the drives one and start the system and if that works connect the other drive one by one and u will find the culprit and if the system is under warrantty contact dell on 18006249896
Posted on Feb 09, 2009
My 1998 Dodge Caravan will periodically beep four times in succession while driving. Does anyone what this indicates? Thanks
There are a number of things that can cause this beeping to happen. Problems in the Air Bag system, Seat Belts, Low Fuel, door or trunk Ajar, Low Washer fluid, Parking Brake on, Going too fast, Turn Signal On, Key-In Ignition, Exterior Lamps ON, Warning Lamp Announcement, or Transmission Over Temperature. You can try the self test to see if there are any codes stored in the computer, if needed.
1. Cycle the ignition key On - Off - On - Off - On within 5 seconds.
2. Count the number of times the Engine light flashes. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. All codes are 2 digits. There are longer pauses separate individual two digit trouble codes.
Jul 20, 2011 | 1998 Dodge Caravan
I have a Kenmore elite dryer, and the signal cycle keeps beeping and the light switches from on to off with every beep...it does it about 6-8 times then may wait 20 seconds to 5 mins b4 it does it again. ...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 09, 2010 | Kenmore 67082 Electric Dryer
94 golf iii makes a beeping sound after it has been driven for 1/2 hour. can't tell if a light is flashing as my dash light is out. The beeping sometimes will continue for 5-10 minutes then stop for 1...
Bring this vehicle into a shop as soon as possible. The beeping noise may be your oil pressure switch telling you there is a problem. Pretty soon the vehicle may not start. I'm not sure if this sensor is tied into ignition system.
May 04, 2010 | 1994 Volkswagen Golf
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    When turned on all i get is fans constantly running and nothing else was working fine up till then
    Sometimes the best answers are the simplest. First, make sure the video monitor is switched ON, securely connected to the computer video port and the "brightness" control set to at least mid-point. Before focusing suspicion on the computer itself, try a different "known to be working" monitor AND CABLE. Failing all the above you should carefully observe a manual re-start of the computer noting the presence or absence of 1.) pilot or drive indicator lights on or flashing, 2.) A beep tone or series of beeps emanating from the computer ( one beep is good - more than one is an indication of trouble requiring a technician ). 3.) Fan(s) running. If you have lights, fans, and a beep but no video, ( not even a blinking cursor in the upper left of the screen ), replace the video or graphics card in the P.C. with one known to be working. This should solve the problem.
    Jan 29, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
    At POST I get 2 short beeps
    it depends on the bios chip maker Here's some other beep codes:
    for Award and Phoenix BIOS:
    1 short beep: Normal
    2 short beeps: CMOS error
    1 long and 1 short beep: DRAM error
    1 long and 2 short beeps: Video card error
    1 long and 3 short beeps: Keyboard error
    1 long and 9 short beeps: ROM error
    Long continuous beeps: DRAM not installed correctly
    Short continuous beeps: Bad power supply
    AMI BIOS:
    1 short beep: DRAM flash error
    2 short beeps: DRAM ECC check error
    3 short beeps: DRAM detect error
    5 short beeps: CPU error
    6 short beeps: Keyboard error
    8 short beeps: Video card error
    1 long and 3 short beeps: Bad DRAM
    1 long and 8 short beeps: Video card error
    Invoking Beep Codes
    If the computer is actually functioning and the computer beeps continuously, then there is a problem with a voltage on the power supply being incorrect or the CPU overheating. IMMEDIATELY go into the BIOS and check CPU temperature, fan speed and voltages
    BIOS Beep Codes
    Annoying isn't it? You have built your computer you switch it on and then nothing happens except a few beeps from the PC speaker. Frustration sets in as you try to figure out what is wrong with it. If you didn't already know the computer has already told you the problem. It can't speak of course but it can direct you to the problem. Its all in the beeps. The BIOS can recognise when the problem occurs and sends a signal out to send a certain amount of beeps through the speaker. These beeps then tell you the location of the problem.
    Unfortunately not all the BIOS' use the same codes as each other. Two of the main BIOS manufactures AMI and Award (now Phoenix) have different codes for there errors.
    AMI BIOS
    # of Beeps Error Description
    1 Refresh Failure The memory refresh Circuitry is faulty
    2 Parity Error Parity error in the Base (1st 64K) of memory
    3 64K Base Memory Error Memory error in the base memory (1st 64K)
    4 Timer Not Operational Timer 1 is not functioning (also caused by error in base memory)
    5 Processor Error CPU error
    6 8042 Gate A20 Failure Unable to switch to protected mode
    7 Processor Exception Interrupt error The CPU on the CPU card generated an interrupt error
    8 Display Memory Read/Write Error Video adapter is missing, incorrectly seated or has faulty memory
    9 ROM checksum error The ROM checksum does not match that of the BIOS
    10 Coms Shutdown Register Read/Write The shutdown register for coms RAM has failed
    11 Cache Memory Bad The cache memory test has failed. Cache memory will be disabled. *** DO NOT enable it ***
    With the first 3 beep codes, its well worth re-seating the memory just to make sure that it's in correctly. 8 Beeps is probably the most common in my experience. Can be caused by a badly seated Graphics card. If you have re-seated it then check with another Graphics card in the board.
    Always check for loose components before sending the board back as this is the main cause of errors on the POST.
    Award BIOS
    Award states that they now only use one beep from there BIOS. This beep is one long beep and then two short beeps. This indicates a graphics card problem. Any other beeps should be treated as a RAM problem first and then the board sent in to be inspected.
    The reason that the Award BIOS only uses the beep code for display problems is that it tries to display the error on-screen if at all possible. If the BIOS cannot initiate the display adapter then this causes the BIOS to make the beep code for a display error, which must be corrected before any other errors can be determined. Memory Test fails and hard disk failures etc will all be displayed on screen
    IBM BIOS
    The IBM BIOS works with Short and Long beeps as well as the Award BIOS. However the IBM one does still have codes to work from.
    Beep Code Error
    1 Short Beep Normal POST, System booted OK
    2 Short Beeps POST Error - Code on Display
    No Beep Power supply or Motherboard error
    Continuous Beep Power supply or Motherboard error
    Repeating short beeps Power supply or Motherboard error
    1 short, 1 long beep System board error
    1 long, 2 short beeps Display adapter error (MDA/CGA)
    1 long, 3 short beeps Display adapter error (EGA/VGA)
    3 long beeps 3270 keyboard card
    Phoenix BIOS
    The Phoenix BIOS works on a slightly more complicated manor than the others. It does display an error code for you and produce a series of beeps. This BIOS produces its beeps according to the hexadecimal code the error produces. The Phoenix BIOS has many different codes for its possible errors and so many different beep codes. Rather than list the entire section here, I have provided a link to the official PDF file containing the codes and how they are derived.
    Phoenix BIOS Post Codes
    System board errors should be looked at by a specialist, Again always try to re-seat components to ensure they are in correctly. If necessary take all components out except for the RAM CPU and graphics card, then try the system. Re-seating components is the number one fix for getting past the POST screen. One badly seated components can cause the entire system not to function. so pick out your bios and follow the steps above to diagnose .hope this helps
    Jan 05, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
    On POST Computer Beeps
    Put your memmory freq lower in the bios settings they are set to high for your type of memmory thats why it beeps or does not show boot post screen.
    Oct 17, 2008 | Asrock 939Dual-SATA2 Motherboard
    Dell XPS 420  PC Desktop Logo
    121 people viewed this question
    Alun Cox
