Question about Panasonic Matshita- | UJ-845-B | USB 2.0 | DVD-+RWRAMDL (GPUJ845BU) Burner
MATSHITA UJ-840D, has disappeared and I can't play cd's/dvd's.
I have MATSHITA UJ-840D, microsoft driver version 5.1.2535.0 on my laptop.
It seems to have disappeared and I am not sure how that happened. Up until last week I could play cd's, watch dvd's, rip/burn etc. But now when I put in a cd, the computer makes a sound as if it's reading the cd. It use to automatically start but then it didn't so I went into Windows media player and it's as if I didnt' put a disc in. Even under my computer, it's not showing anything is in the drive.
So I tried to get help on the computer and the location for MATSHITA shows as: 0(0) and there is a '!' in a yellow circle over top of the MATSHITA and a 'code 39: Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.'
Can anyone tell me what is going on?
Thanks
  • 5 more comments
  • Anonymous Feb 24, 2009
  • Anonymous Mar 01, 2009
    same
  • cvciclark Mar 25, 2009
    Exactly the same as as mattld`s
  • Anonymous Apr 21, 2009
    Thanks, worked on a Acer Ferrari 4000 with XP too..:-)
  • xp42 Apr 21, 2009
    Works on a Acer Ferrari with XP too.. Thanks :-)
  • northernlora Apr 22, 2009
    I followed these steps and now my cd's are playing again. Thank you for your help...it worked well on my Asus laptop.
  • BRETTJ850 May 09, 2009
    i FOLLOWED ALL THE STEPS BUT GOT TO THE POINT AND AHAD NO UPPER OR LOWER FILTERS TO DELETE. aNY HELP?
Before you do this though export your current registry to the desktop by selecting export from the file menu. If this doesn’t work just double click on the exported on to restore it.
1. Start Registry Editor by typing regedit into the start search box in the bottom left hand corner of the start menu.
2. In Registry Editor, expand Computer, and then expand HKEY_LOCAL_MACHINE.
3. Expand SYSTEM, and then expand CurrentControlSet.
4. Expand Control, and then expand Class.
5. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
6. In the details pane of Registry Editor, on the right side, click UpperFilters.
7. Right click and select delete
8. Click Yes when you receive the following message: Are you sure you want to delete this value?
9. Now look for LowerFilters in the right hand panel.
10. Right click and select delete
11. Click Yes when you receive the following message: Are you sure you want to delete this value?
12. Exit Registry Editor
13. Restart the machine
It wit worked for me on Acer with UJ845D XP Good luck
Posted on Mar 25, 2009
  • Thanks Oct 06, 2013
    I have I had the same code 39 problem on my HP dv4000 with UJ-40D for months and was going crazy not finding a solution as no standard troubleshooting system would fix it. CVCICLARK, your registry method was THE ANSWER! Many thanks!! I made one slight mod and that was to NOT delete the Upper and Lower filters in the registry but to simply rename them by adding "DEL" to the front end of each filter name for instance changing the "UpperFilters" to "DELUpperFilters". That allowed me to reverse the process easily without a typo in case it didn't work. The BIG QUESTION I have is what caused these disabling entries in the registry? I suspect it was a standard update at some point and I did not catch the result soon enough to make a connection. Do you have any ideas?
    Correction for "Thanks", CD is a UJ-840D
Yes this is magic, working to my laptop hp Pavilion 4400
vaer thank the original comment , thank again.
Posted on Feb 28, 2010
Had same problem with mattld...and ifollowed cvciclark advice of going to regedit and delete upper filter.it solved my notebook problem hp dv4000 series. i got back my dvd matshita drive and works fine...
thanks bo..you're the best...
Posted on Apr 05, 2009
Thank you very much cvciclark, your solution worked on my Fujitsu XP as well, but unfortunately after 10 days I have problems again... Now it reads Verbatim data DVD but doesn't open Ridisc data DVD. Both dvds have been burnt on my father's pc and they worked when we made them. Now only the verbatim's are working. The others seem to be empty and don't start on autorun. Can it be the brand (quality)? Some dvds have a closed session but on others we left the session open because there was still space. Can that be the problem? Thanks in advance for your answer!!
Posted on Mar 16, 2010
2 Suggested Answers
  • 1019 Answers
SOURCE: My Matshita UJ-840D DVD/CD-ROM Drive Stopped working
i,m assuming this is A laptop Computer ?
The only thing you can try is this:-
go to My Computer/Control Panel/ System/Device Manager.
see if there are any yellow triangles or exclamation marks by your problem device. if so click un-install. then at the top of that page, there is a refresh icon or similar. which will rescan the systems bus.
failing this try add new hardware wizard, in control panel.
finally ensure the device is connected correctly, unlock/remove and re-insert. update any device drivers for this.
Mike @ Compurepair.
Posted on Sep 05, 2009
Matshita Dvd-ram UJ-861H ATA Device Not Working
Use this link to find possible answers to your problem. It is in the Microsoft Community
HP Pavilion with Vista Matshita Dvd ram UJ 861H ATA Device is disabled...
Feb 20, 2014 | Computers & Internet
ASUS M51SN Matshita BD UJ-120 burner does not work - Windows 7
this will be an isue with the drivers for the drive you will have to get the windows 7 drivers
May 19, 2010 | ASUS M51Sn-C1 Notebook
Matshita uj-840d
Hi, usually and error code in device manager means a sofware conflict with the device. You can try deleting the lower and upper filters in the registry if you feel comfortable. Here are the steps:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Regards,
Purito
Oct 20, 2009 | Computers & Internet
My matshita uj-840d is not recognized by my hp pavilion laptop. the software is loaded but my computer does not see the hardware
I think you have to run this Microsoft tool
http://support.microsoft.com/gp/cd_dvd_drive_problems
At the HP site you will also find information and a patch to solve the problem.
Oct 20, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Mike @ Compurepair.
Sep 04, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
Matshita UJ-840D cannot be connected/found
Tried this on my Sony Vaio VGN-SZ650N after completely reinstalling Windows Vista on it and losing access to my this drive. It worked. :)
http://support.microsoft.com/kb/929461
Good luck hope this helps,
ArcheantusAlive
Mar 14, 2009 | Panasonic Matshita- | UJ-845-B | USB 2.0 |...
My cd/dvd drive wont play
perhaps your device is pooped, needs to be replaced
Mar 08, 2009 | HP Pavilion zd8000 Notebook
Matshita UJ-840D CD-Rom Drive
it seems that the best firmware for your drive is here:
http://www.techzilla.info/uploads/MatshitaOEM.rar
read the nfo inside.
Mar 08, 2008 | Computers & Internet
MATSHITA DVD-RAM UJ 85JS problem
I have mashita DVD-ram UJ 850s in acer aspire 3100 that wont play vide while it only plays sound
Mar 05, 2008 | Toshiba Style Bay DVD-RAM Drive Kit...
Computers & Internet Logo
5,236 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
