Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Is there a connector for water line at bottom of door?
A friend of mine bought a side by side kenmore refrigerator and when the movers delivered it they had to remove the doors. At the bottom of the ice maker side door, the water line is disconnected or they cut it to get the door off....not sure. Is there a connector that we can buy to connect the water line again?
  • msshasta129 Feb 11, 2009
    Thanks Tom! We will give it a shot! God bless you and yours.....PEACE..Chris
    Sergeant:
  • 311 Answers
Depending how old the box is there should be a,i call it chinese hand cuff connector.most of the time its a gray color.you may have to look well under there.other wise what you do is cut off a small piece of the tube you what to connect[its a 1/4 ''or 5/16 but if you take a piece with you, you ll be sure],about an inch and go too the hardware store and buy an union to join the two pieces together[it will be a brass union,but you use nylon pheruals[i spelled this word wrong and spell check cant fix it for me,but the people at the hardware store will know what to give you] so wont cut the tu-being. i hope that helps a bit God bless ,tom
Posted on Feb 09, 2009
Why my refrigerator /freezer is leaking water from the bottom front near freezer and water builds up in the bottom of the freezer?
The leak is probably from the small PVC water line leading to the freezer door ice/water dispenser. Manufacturers put a small plastic joiner at that point to allow removal of the door for shipping and installation. That tiny connector can become easily disconnected and leak water onto the floor every time someone presses the water valve in the dispenser. It's easy to fix, Lowes and Home Depot have the fix-it kit for about $5, but you will probably find the existing joiner parts already attached but only needing to be rejoined.
I'll attach a photo of the Home Depot kit. you can also order it from Amazon and have it delivered right to your mailbox. Search for a "refrigerator door water line connector" and you should see a GE part number WR02X11330.
Aug 21, 2014 | Refrigerators
I bought a new water selinoid Valve, hucked it up and the water does not stop at the door. I'm sure I have the lines screwed up BUT what it the correct way, Got a water line diagram??
The problem may not be the value , look under the front of the fridge remove long cover on bottom, you should see the water line that goes into the freezer door and a connector. Disconnect the water line, should be a quick connect and have a cup ready to check the water line and value, place water line from under fridge into the cup and press the switch on freezer door asking for water if water comes out of the water line then the value is opening and you have a frozen line in the door. Please get back with more info, good luck.
Dec 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Nasty tasting ice cubes
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Jul 13, 2010 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Water running out of tube from fridge into bottom of freezer door that leads up to water dispenser ?
Is the water leaking from the bottom of the freezer door ? ( new door ) line is not replaceable inside the door .
Is the water leaking from the tubing at the connector ( about 6" from the bottom of the freezer door ) ( remove both lines from the connector , cut off about 1" of each tube and reinstall into the connector )
To access , remove the kickplate by either removing 1 screw on each side or just pull off ( held on by clips ) .
Apr 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Water dispenser does not work on kenmore side by side refrigerato
remover the water tube from the lower section of the freezer door at bottom you will see this tube and a tubing connector,push and release the tube the line should drain out from the freezer door if not its most likely its frozen,use a hair dryer on the freezer door to defrost line and then reconnect line.
also adjust the freezer setting ti 3 no lower or higher..
nbcrca:)
Apr 11, 2009 | Kenmore Refrigerators
Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
Jul 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
this is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Apr 25, 2008 | Kenmore Elite 20972
Kenmore coldspot freezer door water line
I had the same problem and I would like to replace the whole line inside the door, it was best to get a double sided connector from an appliance parts store. The part cost me about 7 bucks. I then had to So far so good and when cut a small piece out of the front guard where the connector goes. you take off the front guard, measure where the tube broke. The connector comes off when you push one side down.Cut the edge of tube to have a straight edge, but just a little at a time. Just a clean straight edge, it does not have to be perfect!! I used a small pair of needle nose pliers to pull the bit of hose down from the freezer side and then i used my connectors. It just takes a little time and effort. Let me know what happens!!
Dec 25, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
83 people viewed this question
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
