Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint fdw60 , were is the float switch?
Please help
  • 3 Answers
The float switch is screwed to the bottom panel.  If you tip the machine onto its side, you will see a metal panel held on with six screws - 3 at the front - three at the back.  Remove these screws and remove the panel.  The float switch is secured to the back of this panel. It is a white polystyrene block suspended below an electrical switch.
Posted on Feb 16, 2009
  • 311 Answers
The float is a bulb looking thing in the front corner of the inner if you take off the front bottom panel and then look where the float is on the inside and you will see the float switch underneath that bulb in the underneath workings.
Posted on Feb 09, 2009
2 Suggested Answers
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Posted on Mar 23, 2008
Dishwasher is on and connected to water, but no water coming in.
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Aug 27, 2011 | Hotpoint 24 in. FDW60 Free-standing...
Why is my dishwasher flashing on the eco 45 button
This doe seem that the anti flood system has triggered. This device puts the machiene in pump out mode and shuts off the input water supply.
The device is a safety device that triggers once it detects a water leak (pipe / clamp) and consists of a polystireene float and micro switch at the floor of the washer. First check to see if the float has activated the micro switch and then dry the machiene floor and check for leaks.
Jan 25, 2010 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 overfills and spills out onto the floor when
There is a float in the bottom of the tub that is supposed to rise with the water level and tell the machine when it is full. It looks like an upside down teacup, or a little sombrero and should be near the door, but off to one side.
This float might be snagged on something- remove the bottom rack and check for debris (food, utensils, hair, string...) in the tub. Also make sure there is nothing in the rack that is hanging down over the float. With the machine empty try to raise and lower the float with your hand.
If the float appears to be going up and down then check the electrical side of the switch with a continuity tester (ohm meter). It should go from no resistance to open circuit and back again when you move the float.
If that is okay check the wiring and wire ends for frayed wires or corroded terminals from the switch to the controller.
Last item is it could be an issue with the controller.
Jan 15, 2010 | Dishwashers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
Mar 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
How do i find the float switch for a Hotpoing Aquarius FDW70
Open the DW. Look in the front right or left corner of the tub.
You will see a plastic dome.
The float switch is directly underneath the dome.
Remove the toe kick plate and located the float switch from the bottom.
Sometimes they get stuck.
Jiggle it then try the wash cycle.
If that does not work, replace the float switch.
Feb 28, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Location of element
Hi, Hotpoint FDW60 got a concealled element.
You need to unplug and disconnect the dw, lay it flat on its back and remove the bottom tray (depending on the final letter for your model (FDW60G, FDW60P, FDW60T) you might need to remove the side panels and kickboard to release the bottom tray). Carefull with the floater switch. You should be able to locate the element straight away. Replace it and reverse the process.
Feb 09, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint fdw60 trips consumer unit when switch the plug switch
Hi i have hotpoint FDW60 when i swich the plug and the dishwasher starts then you hear the dishwasher filling up it trips my electric in the house.
Jul 19, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher not filling
there is a small float and micro switch behind the LHS cover which if activated will stop the water flow. you will need to remove the top cover(dont forget to unplug from the mains first !). then remove the side cover, you should find a clear plastic unit with a red float in side this maybe gumed up with scale. if so you should clean to allow the float to be free. this float activates a micro switch via a red arm. if this switch is stuck in this will stop the water flow. or the switch maybe faulty.
May 31, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW 60 Float and Filter Clean problem
Blockage in internal pipework causing water not to circulate fast enough to stop switch activating. Regards Advisor
Aug 17, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
792 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
