Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
Changing bits Can't figure out how to release the phillips bit! Bought the pivot plus second hand, and for the life of me can't figure it out
  • Anonymous Feb 11, 2009
    help me get this piece off this drill, its a pivot plus. how do i change bits
  • 2,176 Answers
Without a model number I am guessing but you should have to either pull back on the outer collar or push forward to release the bit in the hex driver. If this doesn't work give me the brand and model number and I will find a user manual to look at and let you know where you can get it.
Posted on Feb 09, 2009
I have an other brain teaser! bought a laptop (sony vaio) it had vista on 32bit.i upgraded to win.7 ultimate. 32bit. could it be maybe it is a 64 bit base? nota geniouse but could this be why my bat
Beginning with the release of Microsoft Windows Vista, 64-bit operating systems are slowly becoming extremely prevalent in today's market. 64-bit operating systems are poised to eventually replace 32-bit operating systems entirely. At the present however, 32-bit applications still vastly outnumber 64-bit applications. Luckily, 64-bit operating systems are capable of running 32-bit operating systems. In 64-bit operating systems, 32-bit applications are installed to a second program files folder, named "Program Files (x86)." Programs installed in the x86 folder can be initialized just like programs installed in the regular Program Files folder.
Open the 32-bit programs folder. Go to Start > Computer > Local Disk (C:), then click on "Program Files (x86)." Open the desired program folder. The executable file for the program will be located inside the folder. Double-click on the file with the ".exe" file extension. As an example, for the QuickTime program you would double-click on the "QuickTimePlayer.exe" file. You have now successfully run a 32-bit application in your 64-bit operating system. Hope this helps.
Dec 08, 2012 | Computers & Internet
Pivot Plus PD600 drill bit problems
pull the very front bit back that holds the drill Re: Jeff
Apr 10, 2012 | Black & Decker Pivot Plus Cordless...
How do i change the bit?
It just pulls out if its a screwdriver and if it has a quick release chuck then pull chuck back towards drill body and pull bit out.
Feb 02, 2011 | Black & Decker Pivot Plus Cordless...
Have never used a hand dill, how do i change the drill bit. i need to drill a small hole. thank you anne
Typically, the end of the drill where the bit is inserted (called the 'chuck') rotates to loosen or tighten the arms holding the bit in place. Grasp the top of the drill with one hand and rotate the end the bit is inserted into counter-clockwise if the bit end is pointed towards you to loosen the arms and release the bit.
If it is an older drill it may have a 'key' that would look similar to end of a phillips screwdriver on a tee that can be inserted into where the chuck and the rest of the drill assembly meet and twisted to loosen the bit.
If neither of these work post what type of drill you are using as not all hand drills are the same. Hope this helps.
Dec 10, 2010 | Garden
THE BIT DOESNT STAY IN PLACE
Could be 2 problems, first are you using the right type of bit to lock in this tool and second the ball that locks into the detent of the bit might be stuck or the ring holding it in has moved. Give me a brand and model number and I will find a breakdown for this and see if I can give you more help
Jul 27, 2009 | Black & Decker Pivot Plus Cordless...
Bit problem
Just read part of the manual and it says hold tool upright and pull down on the collar and "simply" remove the accessory. If this is not the case on yours I would have to think that the shank on the bit may be twisted and then you would have to find another method to remove it. Let me know if the second opinion is correct. Good luck
Feb 11, 2009 | Black & Decker Pivot Plus Cordless...
How to change drill bit on black & decker plus pivot cordless drill How to change the bit on a Skil cordless screwdriver 2362 with a keyless check?
Grab the end of the chuck in one hand, and the outer ring of the chuck nearer the motor, and twist the chuck end. try both directions until it loosens.
Jan 28, 2009 | Drills
Black & decker pivot plus bits are stuck
I had this problem too, an unfortunately, there's no manual on the black & decker site for this product.
I figured it out though! You have to push down (towards the motor) the chuck collar (cyllindrical black part which holds the bit). If you've tried this already, try harder - it can get really stuck and require a lot of force to push down.
Anyways, if you apply enough force, it will give and allow you to remove whatever bit is inside.
Hope this helps.
Dec 23, 2008 | Black & Decker Pivot Plus Cordless...
Pivot plus Drill
see www.dewaltservicenet.com . look for the icon find it now & enter the model #
Jul 13, 2008 | Black & Decker 9072CTN Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
325 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
