Question about Pioneer PRV-9200 DVD Recorder
REPLACE HARD DRIVE
To replace hard drive in pioneer DVD recorder PRV-9200 [or even in general terms] 1. What format does the hard drive need to be and
2. any system files need to be on that hard drive ? [if so where would you get that info]
melnavz
  • 1226 Answers
SOURCE: Hard drive shows full even after erasing 120 hours.
You should empty the recycled bin in the system and delete all temporary files on it.
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: dvd recorder wont finalize etc
The DVD drive works harder when trying to record the info faster. As the unit ages, tracking is less precise. DVD-R copies occur at 4-16X real time. Try DVD-RW disks which copy slower (now that the price has dropped substantially), and you may find that your aging drive can still copy programs from the HD to the DVD.
Posted on Mar 22, 2008
SOURCE: Pioneer DVR-633H-S hard drive problem
do the Reset to factotry settings,hold two buttons same time {STOPand STANDBY}on front off your unit and unplaged the power from the wall same time.wait like 5minutes,and pluged back the power,this my work,did work for me.
Posted on Nov 10, 2008
adnanbhatti
  • 1188 Answers
SOURCE: need a service manual for Pioneer DVD Recorder
The manual is available but for a fee of $10. Only pay if you trust the site is legitimate:
PRV-lx1-dvd-recorder">SERVICE Manual Pioneer PRV LX1 DVD RECORDER
You will find some use full troubleshooting guides here on this page:
Just scroll down and download pdf files which you think might help you.
Note: I have no affiliation with any of the above sites. They are for your reference only.
Posted on Sep 10, 2009
SOURCE: Pioneer PRV-LX1 DVD Recorder will not initialize.
connect a keyboard and hit F1.
Posted on Nov 28, 2011
Funlux surveillance hard drive issue. 1 tb, is full, need formatting , it takes 5 minutes plus to format. Every 2 minutes it reboot, trying to record, won't finish formatting. Disconnected cameras,
You did not post the model of the unit. There is a port for external drive support and there is an internal drive depending on the model. You can try formatting on a computer if you would like or you can select OVERWRITE recording when the HDD is full
1. Access the [General Settings] and open the [Disk Drive Info] page. 2. Open the drop-down menu at the top next to the "Hard Disk Drive Full", select "Overwrite" and press save.
Jan 07, 2017 | Hard Computers & Internet
I have a zoom mrs1044 multi tracker recorder and would like to know if the hard drive could be replaced. It is made by Samson.
Yes,the hard drive can be replace.
MRS1044 use general hard drive, 3.5 inch E-IDE type, 15 GB.
You can replace with bigger capacity.
Don.t forget to format it within mrs1044.
Mar 07, 2015 | Zoom Music
How to take off face plate pioneer PVR 9200 DVR
You will need to remove the drive from the chassis first. Then take a long slender probe and insert in the hole to release the media tray. Once the tray is extended you will be able to pry the face plate off by pressing the tabs that click it in place.
Aug 23, 2014 | Pioneer DVR Computers & Internet
All saved recordings have disappeared from menu. system has reset itself and now all recording in the HDD play menu have disapperaed. They must still be on the HDD because nothing else has been...
dissambling and taking the hard drive out of the dvr will most likely void the warrenty how it is possible.
once the hard drive is removed you may be able to plug it into your PC and gain access to the files on the hard drive. These how ever may be specially encoded and protected files that you cant open.
-you PVR may have also done a hard reset and formatted the hard drive. This would delete all the files on the PVR.
-unlike tapes, erasing a hard drive does not require you to record over it. just because nothing else has been recorded does not mean your data is still there. sorry.
Mar 01, 2011 | Pioneer DVR-720H-S DVD/HDD Recorder
Dell optiplex GX280 decommissioned and hard drive formatted to remove business records. MS Windows XP Professional reloaded and the computer was restarted as per instructions. Nothing at all happened. No...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 20, 2011 | Dell Optiplex GX280 (99301) Motherboard
Need a service manual for Pioneer DVD Recorder PRV-LX1
Sep 10, 2009 | Tascam Pioneer PRV-LX1 2(4X) DVD Recorder...
Restarted my LX1 and gets stuck on FSck-Data on the display.
Called Pioneer-said my hard drive or data is corrupt-have to send in for repair-flat rate of $695.00 to repair.
Aug 27, 2009 | Pioneer PRV-LX1 DVD Recorder
DVR 450h keeps freezing and says to get to a repair shop but how do i know where to get repair and would like to do it myelf, The disk is okay, i thinnk i need to download driver or something...thanx
Hi, I am a technician. to solve this problem you have to change a new hard drive or re-format the old one.
After replace or format you must have a pioneer service remote control in order to enter the serial number ID for bios system to recognize the hard drive and the DVD drive in the system, otherwise the recorder will not work at all with the new hard drive.
For more information you can e-mail me at
sereyvutha2@netzero.net
good luck.
Dec 06, 2008 | Televison & Video
Jan 10, 2008 | Pioneer DVR-640H DVD Recorder/HDD Recorder
Faulty hard drive
Your hard drive needs to be replaced. They don't tell you in the operators manual, but these drives are extremely vulnerable to shock (even a 1/4" drop can kill them) and temperature change.
These machines are not sophisticated enough to mark bad sectors and work around them. Without a new hard rive, your machine will not work.
It is very unlikely, but there is a tiny chance you could reset the hard drive with a service remote. But considering how expensive and difficult it is to get a service remote, it is not worth the effort. You would also need a service manual, whic BTW is not particularly good, so you would need a lot of time and the chances of success are very small.
Considering repair costs, you may be better off financially to get a new DVR.
Oct 01, 2007 | Pioneer DVR-520H DVD Recorder
Pioneer PRV-9200 DVD Recorder Logo
88 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
