Question about LG DLE5977 Electric Dryer
LG dryer check filter light
I am getting a check filter light when I turn on the dryer. The power only stays on for a second then turns off..... how do I fix this?
  • 3 more comments
  • karen637 Feb 12, 2009
    Yes, I cleaned the lint trap, took the vent line off cleaned it out even though there wasn't much but dust in the line. I even tried to unplug for 1 min.
    The problem is when I push the power button the dial lights up and then the power goes off immediately. What to do?
    How do I get to the computer???
    I guess i will have to wait for my husband to come home, I am not sure where the 4 screws on the face plate are.....I don't see any screws. Is the face plate the dial or the front of the dryer? Sorry I am not getting this....
    I don't see any screws on the dial. I have the Tromm DLE5977W LG electric dryer........
  • karen637 Feb 15, 2009
    I havn't heard back from you? I still don't know how to get to the computer.....
    President:
  • 1,902 Answers
Have you checked the lint trap? If not this is what it is talking about. If you have then you should check your dryer vent line. Your lint trap should be on the inside of the dryer. If you need more help let me know. Also if you unplug the unit after checking what I said and the light still is one. Unplug it for 1 minute then plug back in this should reset everything
Posted on Feb 09, 2009
  • 2 more comments
  • Jeremy Reddick
    Jeremy Reddick Feb 12, 2009
    Ok then what has happened is your Sesor has tripped. You are going to have to unplug the unit get to the computer that is behind the knobs. Unplug the wires then plug everything back in after giving it 60 seconds. That is how you reset it. If this doesnt work then you are going to need a new computer. There have been lots of problems with this system with bad computers. If this has helped you please rate. Thank you
  • Jeremy Reddick
    Remove the face plate. 4 screws 2 on each side. Remove those screws and the face plate comes of and you will see the computer right there
  • Jeremy Reddick
    The dial
  • Jeremy Reddick
    Jeremy Reddick Feb 15, 2009
    Im sorry. Put you on the wrong board. To get to the computer and everything else you are going to have to pull off the back of your washing machines. In order to do this.
LG Tromm Dryer Won't Stay On!
Your motor might be weakened. As when you start is back does it come on if it does then we are looking at venting issue.
Oct 06, 2017 | Dryers
Their is no hot air flowing. I cleaned the lint filter took off the sendors and cleac\ned them. and also checked the hose assembly and its cleaned. Is the red check filter light always blink when you first...
that light will blink a couple of times when the dryer is first turned on , if it stays on all the time, unplug the machine for 5 minutes and see if it resets
Jul 04, 2011 | LG Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Dryer model DLE5955W is not heating. When drying the "drying" light flashes and the "cooling" light is on steady. I turned off, turned breaker off and back on. No improvement. Checked lint filter, all...
You have one of 2 problems. There is a power problem at the power cord or the high limit switch has tripped. You will need a qualified LG technician to diagnose your situation.
Good luck
Oct 01, 2010 | LG DLE5955 Dryer
LG dryer not working
if the light comes on when you power up the unit, the filter may not be properly inserted.
You can find a copy of your owners manual --->here<---
please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | LG DLG2525S Electric Dryer
Dryer powers up but stops within 4 seconds. Is louder than normal. When I press the power button, the check lint filter message lights.
Oct 30, 2008 | LG Dryers
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Owners manual
The "check filter" light comes on just when I start the drying cycle the light goes away but the "Cooling" light comes on and stays on throughout the drying cycle, clothes stay damp thus a second drying cycle. Due to this annoying problem with my LGDLE2512W my laundry time has doubled, taking over 3 hours and a high gas bill just for a medium size load of laundry....
Aurora Tracy
Sparks, NV
May 20, 2008 | LG DLE2512W Electric Dryer
LG Gas Stacking Dryer
The check filter light comes on every load to remind you to clean the lint filter. Cooling only happens when that light is flashing not when it's on solid. If this is a gas dryer check the exhaust hose and vent on the outside of the house. If it is blocked it will not let the unit get to the correct temp due to cycling.
Dec 16, 2007 | LG DLE2514 Electric Dryer
LG DLE5977 Electric Dryer Logo
1,303 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
