Question about Fellowes DM8C Cross-Cut Shredder
Paper stuck in the Fellows Paper Shredder
I use a Fellows medium sized paper shredder and it is REALLY stuck. There is paper stuck so far in that is nearly impossible to get it out. I have been doing it by hand with a pen and its taking forever. Any other ideas? It won't move forward or backward when turned on. The red light goes on so not sure what to do.
  • Anonymous Mar 12, 2014
    feeding paper does not turn on the motor
  1. Remove Shredder from paper catcher bin
  2. Remove shredder cover from shredding mechanism assemble (approx. 6 screws on bottom of cover)
  3. Separate shredding mechanism from bottom cover (may have disconnect circuit board from assembly and other wiring from switches , sensors, etc,)
  4. Remove motor gear cover (approx. 4 screws)
  5. Separate shedder main drive gear from motor step up gear by pulling gear out
  6. Turn shredder mechanism up side down to access the cutting blades
  7. Use an adjustable wrench to turn the main drive gear to see stuck paper
  8. Use a needle noise pliers to remove paper shreds
  9. Repeat step 7 and 8 until all shreds are remove and cutting mechanism move smoothly
  10. Reassembly before testing shredder
  11. If you remove only some of the shreds, the motor may seize up and strip the plastic gears from step up gear.
Posted on Mar 05, 2009
  • tprimont292 Sep 11, 2014
    you made too hard. just poor water in blades and wait a little than try it
Looking for a basket for a fellows 65c
You can only buy new one or block a microswitch inside. Basket from Fellowes PS-67Cs can be used too. If you use this shredder privately just block the microswitch.
Nov 10, 2014 | Fellowes Powershred PS-65C Medium-Duty...
HOW DO I OIL MY FELLOWS P-35C SHREDDER
You can squirt some shredder oil onto a piece of paper & shred that paper.
Mar 31, 2011 | Office Equipment & Supplies
Does it make a difference which shredder oil I use? There are so many. I have a Tech Solutions cross cut TS8000.
You can use any kind of shredder oil. They are all priced so differently, I use fellows brand for my royal shredder & it works just fine.
Feb 07, 2011 | Fellowes WilsonJones Q4 Paper Shredder Oil...
MY FELLOWS GD1200 SHREDDER IS REALLY JAMMED WITH PAPER.WENT TH SHRED ENVELOPES AND TOO MUCH PAPER WAS INSIDE.hOW DO I UNJAM THIS? iVE TRIED REVERSE SLOWLY THEN FORWARD,ETC.IT IS STUCK BADLY.I SAW AN ANSWER...
First, UNPLUG IT!
2 - Then remove the top. shredding part and flip it over.
3 - Carefully, with your fingers, not a pliers, remove all the paper bits and pieces from the underside of the shredder.
4 - Turn it back to right side up, and place it on the basket as it should be positioned, then plug it in and turn it on in REVERSE first.
5 - Once it starts, let it run until it stops; it should only be a couple of seconds.
6 - Turn the direction back to normal, and see if it will run that way.
Good luck,
-a.
Apr 21, 2010 | Fellowes OD1200 Shredder
Cannot get it shred forward or reverse. Is there a reset or fuse Paper shredder
probably has broken gears. Aurora does not produce replacement parts for any of their machines. Actually made by Royal and they don't make parts either so don't buy either brand.I guess Fellows is about the best brand or GBC.
Nov 13, 2009 | Memorex Paper Shredder
Exploding paper shredder - very dangerous
I'd call your lawyer and tell him you can't touch any machinery which contains an electric motor because you have been psychologically damaged. Maybe Fellows will settle out of court.
Otherwise ring your local 7:30 current affairs news program.
I don't know why their motor would not be shielded from paper dust.
It is no big surprise that it may be dusty in there.
I'm glad you did suffer any permanent physical damage.
Oct 05, 2009 | Fellowes DM15C Shredder
We need to purchase the part for our Fellows P45C paper shredder. We need to get the part that clears the paper from the blades. Where would we get this from?
You can order it from a dealer, such as me, or from Fellowes. My info is in the repair directory under Blair Business Machines
Jun 19, 2009 | Fellowes Powershred P-45C Shredder
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Fellows paper shredder
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Mar 29, 2008 | Fellowes DM8C Cross-Cut Shredder
How to fix a stuck shredder
Go to your local hardware store, and pick up a quart of 3 in 1 oil, shredder oil or some other light weight oil. (With the shredder in the off position or unplugged). Use a couple of ounces and Pour the oil over the paper that is jammed in the shredder. Use enough oil so it saturated the jammed paper. Wait about 10 - 15 minutes so the oil really soaks into the paper. Don't go crazy with the oil, and keep in mind what goes in, must come out. If you pour too much oil in the shredder, the exess oil will drip out. Don't worry about having oil in the shredder blade, this will help lubricated the teeth, and it will actually make your shredder blades last longer.
Now try to turn your shredder on after the oil has soaked into the paper for 10-15 minutes. Hopefully, the paper that is stuck has gotten softer, and then it should pass the paper. If it still doesnt work, then, try some more oil on the paper, and then wait and then turn the shredder to the forward, and then reverse mode, and then back and forth.
Hopefully your shredder will be unclogged by this time.
Hope this helps.
Good luck.
Feb 04, 2008 | Office Equipment & Supplies
Fellowes DM8C Cross-Cut Shredder Logo
2,054 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
