Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven burner makes a popping or whistling sound during baking cycl
GE Spectra XL44 LP gas range about 8 years old.
  • 3 more comments
  • nnsmythe Feb 10, 2009
    The range is a spectra xl44. There are leveling legs and the noise being made sounds like a torch when the gas burner ignites during a baking cycle.
  • kenlange Feb 13, 2009
    our xl 44 does he same thing, when baking the gas keeps turning of and on off and on and makes a popping sound like a blow torch every time it turns on again. It heats up correctly but does not sound safe.
  • Anonymous Mar 18, 2009
    I'm so glad other people have the exact same issue with the XL44 - I just had someone come fix it and I believe the problem (for me) was that the thermostat wasn't working properly so because it wouldn't heat up right, that's what caused the popping/blow torch sounds. They replaced it - I'm going to bake tonight and hope it's all fixed!
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    The model number is on a sticker behind the drawer front. It generally starts with a "J" as in JGBS...... or JGBP.....
    Has this just started recently? Done any work lately, like replace the flooring in your kitchen?
    Not sure if I can help with this, but I might have an idea. Could you confirm model number and tell me if there are indeed leveling legs installed on the range?
  • GE Master
  • 3,361 Answers
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
GE Profile Spectra XL44 oven- Makes a popping noise while heating up
assuming you have a gas rang here sounds like a bad ignitor, too long to light causes a "popping "noise when it finally does, as well as extending cooking time and perhaps slight smell of gas while cooking, all signs of bad ignitor.when you start the oven should light bake bar in 40-60 secs. any longer, bad ignitor
easy part to replace yourself part num wb2x9154, remove bottom of oven cavity, 2 screws mount ignitor to burner and 2 wires lead from ignitor( use wire nuts provided if needed . and makes no difference which wire goes where theres no polarity.
Feb 26, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Lower oven burner will not light.
Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 propane to natural gas conversion.
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL44
Sister, there is no pilot light on this model. Sounds like you have a bad ignitor, however the F7 code shows as a bad touch pad membrane. d7 must represent how many times this fault occured, although Im not finding anything that shows a d7 code. Try resetting the board by killing power to the range for about a minute. After turning the power back on press the COOKING TIME, DELAY START AND NUMBER 8 PADS ALL TOGETHER. The words test should be displayed. Now you are going to energize the bake circuit; press the bake and start, you should hear a click, this is the bake relay on the board. By holding the start button in you are energizing the ignitor (glow bar) in the oven. If you do not hear the click, suspect the control board. If you do hear the click and the ignitor is not glowing, you have a bad ignitor. Have someone with you to verify the ignitor is glowing when you are holding the start button in. To exit the test, just push CLEAR/OFF key pad. Catriver...post back
Oct 23, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,218 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
