Question about Insignia Digital-to-Analog Converter for Analog TVs
I have a spliter on TV for special religious satilite stations
My DVD and VHS all go through a switching unit. My Magnavox converter will not come on
  • 57 Answers
To use your converter box try selecting converter on your switching unit.
I hope this solution is helpful. Please take a moment to rate this solution.
Posted on Feb 11, 2009
I cannot record digital when I try to set up my Magnavox ZV457MG9 (DVD). The unit will only record in the external L1. I have a Comcast box.
This is normal for the ZV457MG9 units. The Magnavox ZV457MG9 does not have an analog (NTSC) tuner; additionally there is no digital (ATSC or QAM) tuner either. It will only record on line in (L1) which is a composite input (limited to SD). The HDMI port on the recorder is an HDMI out to TV, not an input. The component video jacks are also only outputs.
The manual for the Magnavox ZV457MG9/F7 is available here: http://download.m4c.magnavox.com/files/z/zv427mg9_f7/zv427mg9_f7_dfu_aen.pdf . The unit was manufactured for Magnavox by Funai; thus another link to the manual is http://www.funai-corp.com/6pdf/om/ZV427MG9.pdf .
I wish that I had better news for you.
(If your DVD/VCR recorder had a tuner, it would record off a coaxial (antenna) cable input. Many DVRs can record off the HD connection (HDMI or component); that may be a better option for replacing this Magnavox unit.)
Oct 01, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
My manavox tv dvd/vhs unit is hooked up to a converter box. All I had to do was turn on the converter box and then the tv. It was working just fine untill I cut if off one day, instead of leaving it on...
  1. Try unplugging the converter box from the power, and RCA or Coax connector. Reconnect the power and RCA or Coax connector. Try turning it on.
  2. Look for a reset button. May be a small hole with a button inside, if you find one use a paperclip or similar to press it.
  3. Try the converter box with a different TV.
  4. If this doesn't fix the problem, replace the converter box.
Feb 22, 2011 | Philips Magnavox 20MC4304 20 in....
Transfer VHS recording to DVD . I have recordings on VHS tapes and would like to transfer them to DVD discs.
Try hooking up an external DVD player to the unit. Remember, the jacks are color coded and never connect an OUT to an IN or vice versa. Your unit might have a special channel in which you can watch DVDs with the VCR part left on, try recording from this too. Good luck to you!
Jan 01, 2010 | Philips Magnavox DVD/VCR Dual Player
I bought a 1995 magnavox at pawn shop today and a attenna but tv wont let me select vhs/uhf attenna mode so the tv just snowy do you know how i can get it onto vhs/uhf mode. I believe this is a phillips...
This would be VHS only that i know of if you do not have a remote to switch to the other side is what you need its available at www.remotes.com but I beleave this is VHS only. thanks
Aug 19, 2009 | Philips Magnavox MPD845
I have a Magnavox ZV427MG9 A VHS & DVD Recorder
U must make sure ur tv channels must work throught ur DVD and VCR unit.Then u can record it out the tv show programs.U must connect the tv air signal or cable to the DVD VCR unit in the antena port.Use another cable connect out on the DVD &VCR unit and in the tv signal input in ur tv antena input.Make sure u in the channel 3 or 4 switch desire back of the DVD&VCR of the back,and the tv correct to ur desire channel switch to 3 or 4 .U
can record tv shows now.
Aug 18, 2009 | Philips Magnavox DVD+R/+RW Recorder/VCR
DV220MW9 DVD/VCR: won't record video on VHS
your cable tv connect into dvd/vcr,video/audio out connect to av in your tv,solved
Jul 06, 2009 | Philips Magnavox DVD/VCR Dual Player
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
LG V8824W combo DVD VHS player
LG V8824W combo DVD VHS player can I copy VHS to DVD?
Oct 20, 2008 | LG Televison & Video
Insignia Digital-to-Analog Converter for Analog TVs Logo
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
