Question about Creda W100FW Front Load Washer
Creda Simplicity 1000 Washing Machine not heating water
Creda Washing Machine Model W100FW is not heating the water, but it still completes any program. The only HOT water is taken in at the start of the program from the HOT supply.
Surely the machine should not complete the program until all parameters are satisfied.
I cannot access the heating element as there is no panel to remove in the drum.
Anyone any ideas?
  • phyllisruth Feb 10, 2009
    barkencoa,
    Many thanks for your very detailed answer to my problem.
    On checking I found the energy save button out and showing green.
    So hopefully the heater will be O.K.
    I will keep a note of how to access the heater for the future.
    Regards,
    phyllisruth
  • Creda Master
  • 3,463 Answers
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Thankyou.
Posted on Feb 10, 2009
Water comes up through soap dispencer when spinning
Posted on Oct 16, 2009
Creda Simplicity 1000 (w100fw) - Drum does not rotate
you could try fitting new motor brush kit it wears down after 4/5 years and need replaced....please leave feedback
Apr 08, 2010 | Creda W100FW Front Load Washer
Need operating instructions for creda simplicity 1000
laundry.manualsonline.com/manuals/.../creda/w100fw_w120fw_w120vw.html -
Mar 22, 2010 | Creda W100FW Front Load Washer
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
I need a manual for a Creda Simplicity 1000 washing machine as I have mislaid mine
In your browser bar, type in:WWW.HOTPOINT.CO.UK.
Click on after sales, and follow links.
Pease rate my solution.
Thanks.
Jun 30, 2009 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer. access to service drain plug?
Hi.
Remove lower rear cover of washer, locate pump, and remove large hose attached to it, remove and clean filter inside hose, check pump for possible blockage.
Please rate my solution.
Thanks.
Apr 19, 2009 | Creda W100FW Front Load Washer
Creda 1000 simplicity washing machine
try
www.theservicecentre.co.uk
creda and hotpoint website
good luck and rate me
Feb 17, 2008 | Creda W100FW Front Load Washer
Creda simplicity 1000 door hinge
I had the same problem and got a new one on ebay
Nov 30, 2007 | Creda W100FW Front Load Washer
Creda W100FW Front Load Washer Logo
719 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
