Question about Moen Plumbing
Moen Villeta 2 handle bathroom faucet, need to disassemble
How the hell do you take the handles apart? My hot handle is loose and in two sections, I don't see any screws or allens Do I have to take the whole thing off the sink? Any help would be greatly appreciated
Model #: TL4734
    Problem Solver:
  • 11 Answers
Hold the handle and twist the piece below that doesnt turn, anti-clockwise, it should unsrew and the handle should pull off.
Posted on Feb 11, 2009
Hot water handle got loose then eventually popped off this model Moen L4720 Villeta faucet. Where can I go for detailed repair instructions?
http://www.moen.com/shared/docs/exploded-parts-views/l4720pt.pdf
i just sent you a clarification request. The link above is an exploded parts diagram. You should be able to get some of these parts at lowes or home depot. Especially the cartridge.
No really all you have to do to change them out is turn off the water supply, and use the diagram to tell which parts go on when. I doubt you will be able to get everything from the store. But you can probably get any part on there from the moen website.
I hope this helps. I will be more than happy to help you further if you need it.
Thanks,
Mike
Jul 27, 2011 | Moen Villeta Chrome Faucet W/ Valve &...
L have a moen kingsley t125 with a moen 9000 m pact the cold water handle comes out with a trickle only when you turn it on the hot water is find unit is about one year old
You have a obstruction in cold side turn off both cold and hot water to faucet then disassemble cold side(take note of how you take apart it must go back correctly) slowly open cold water stop to see if you can dislodge obstruction(use a towel over cold water handle assembly to keep from water shooting everywhere).
May 30, 2011 | Moen Kingsley Two Handle Bathroom Sink...
I have a handle that came off a Moen Villeta 2 handle bathroom faucet. It is not obvious, no set screw etc., of how to attach the handle. Also, the stem that the handle attaches to, seems to have dropped...
Sorry to read about your problem, I hope this helps you out.
under the moen symbol is a set screw
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Moen & Villeta Two Handle Lavatory Faucet
How do you remove the handle on a MOEN T 4570 faucet to replace the cartridge?
Don't turn the handle, but turn the body counterclockwise until the handle falls off.
Oct 31, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I was able to figure out how to get the handles apart, but can't figure out for the life of me how to get the center spout removed. Faucet is a Moen & Villeta Two Handle Lavatory Faucet
I took a look at the brand on the web and though I do not know your model, it appears that the center spout would have to be loosened from down under the sink and then pulled up from the top. Those units usually come in three parts, two valves and the spout. The valves are put in from under the vanity/sink and the spout is put in from above the vanity/sink.
Sep 15, 2010 | Moen & Villeta Two Handle Lavatory Faucet
HAVE MOEN MODEL INS792A WIDESPREAD 2 HANDLE BATHROOM FAUCET - LOOSE HANDLE ON LEFT SIDE - KEPT INSTRUCTIONS (PICS ONLY) - CAN'T FIGURE OUT HOW TO TIGHTEN LOOSE HANDLE - HELP??? THNX!
There is a cap on the top of the handle which can be removed by popping it out with a knife or a small flat tip screw driver. Inside you will see a screw which holds the handle to the faucet. Tighten this and replace handle cap.
Sep 01, 2010 | Moen & Villeta Two Handle Lavatory Faucet
I have a loose handle on my Moen two hanlde lavatory faucet and i can't find any set screw to tighten it . How to tighten the handle to the faucet stem?
Take handle off and check out the inside to make sure it not striped out and on the top of the handle it may have a plastic cap to pop of to access the screw holding in in place you amy have to use a knive to get it off .
If you can't see a set screw it may have a screw in handle on top.
May 03, 2010 | Moen & Villeta Two Handle Lavatory Faucet
Leaky moen 2 handle faucet
if memory serve's me,you will need to remove a stem extension,screw in center,and you may need a tool #103462 to remove cartridge.1'st stem ex't is red,(hot) blue (cold), remove, look down,white piece w/ 2 notch'es, this hold's cartridge down, ya might try needle nose plier's to remove,a little lube help's upon re assembly, carefull w/plastic thread's
Apr 26, 2010 | Moen Monticello Single-Handle Kitchen...
How do you take a moen bathroom Model #: 84206 apart to fix a drip? Hot water side has a slow drip. Need to replace a seal. How does it come apart?
On the handle it self you should see a red and blue button plug. Remove this and you will see set screw. Remove handle, remember to shut off hot and cold water supplies under sink before you go any further.
Oct 03, 2009 | Moen & Villeta Two Handle Lavatory Faucet
Plumbing Logo
825 people viewed this question
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
