Question about Singer 2638 Mechanical Sewing Machine
Singer model 2638 will only straight stich all of a sudden
Was zig zagging just fine then it quit and will only straight stitch now. Anyone ever had this problem before and do you have a solution.
  • 1 more comment
  • angelinad Mar 11, 2009
    My singer 2638 won't do anything but straight stitch no matter what I set it to. Very frustrating. I changed the needle, oiled and cleaned the machine. Any tips?
  • Kim Blastow
    Kim Blastow Aug 07, 2015
    Did you ever find a solution to this problem besides changing the needle?
  • Kim Blastow
    Scholar:
  • 69 Answers
Try changing your needle. That is the most common cause for this. If you hit a pin or broke a needle, it could have been thrown out of time. Try changing the needle, that will in all likelihood correct the problem.
Posted on Feb 12, 2009
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
HOW DO YOU CHANGE THE STITCHING FROM STRAIGHT TO ZIGZAG
Check that your sewing machine is even capable of zig-zag. Some machines are straight-stitch only.
Consult your owner's manual.
If your machine can do zig-zag, somewhere there is a dial or setting called "stitch width" that will determine how wide the zig-zag will be.
May 21, 2016 | Sewing Machines
When i use the zig zag stich, sometimes the stich falls and does not zig zag
try a new needle--one for the fabric being sewed
could be a problem with the cam that does the zig zag, you might need to have the machine checked
if your sewing with light weight fabric also try using stablizer
Mar 18, 2016 | Singer 5532 32-Stitch Heavy Duty Sewing...
How do I get it to zig zag
There is a dial or a lever that you turn it to. It usually has a straight line picture for straight stitch and a zig zag photo for the zig zag stitch.
Mar 01, 2015 | Sewing Machines
Singer Sewmate, the zig zag stitch is perfect on the bottom of the fabric, but lopsided on the top, how do I fix this?
This could be a combination of two things, to much down pressure on the spring loaded foot on top or the fabric distorting it, the other is a top stich tension issue adjust tension in and out to see if this improves the stich.
good luck
Feb 25, 2015 | Singer Sewing Machines
Why won't my zig-zag zig zag?
Check your stitch width setting if its too low it will just straight stitch.
Jan 21, 2015 | Sewing Machines
White sewing machine won't stop the zig zag stitch
my suggestion is take the machine in to a sewing machine shop
to be check to see if something inside is broken or come loose
knowing the machine is in good working order gives peace of mind
instead of wanting to through it out the window
and get a instruction manual
Go to the singer website for a free pdf manual
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example w265) & click search
Jul 24, 2012 | Sewing Machines
Someone gave me a singer 403. I put in the zig zag attchment but it still sews only straight. What am I not doing??
Of course, you have to push the zig zag adjusment lever from the 1 position to one of the zig zag positions, 2-5. Also, the zig zag disc must be inserted. Take of the top of the machine (two screws to loosen the attachment and lift off the top), and you can see a steel connecting piece called the pitman and it should move back and forth when zig zag is engaged. If it isn't, maybe something is gummed up as has been suggested.
Jul 20, 2012 | Singer Sewing Machines
Singer 2638 Mechanical Sewing Machine Logo
231 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
