Question about Dell Inspiron 2200 Notebook
Battery not charging
The ground on ac plug is missing could this cause battery not to charge on my inspiron 2200?
  • chucka77 Feb 09, 2009
    Thanks! Was just told by prev. owner battery is @ 3 years old. Yea.
  • 6,784 Answers
Your cell is bad. it doesn't matter if the ground isn't attached. you can still get a charge.
Posted on Feb 09, 2009
  • Michael Masters
    Michael Masters Feb 09, 2009
    yea, that cell is gone. thanks for using fix ya:)
  • 382 Answers
If the plug is not using correct current in correct location, ie plugged in backwards yes it will not charge unit properly.
Hi i need help plz, i've my laptop do not power when i plug the ac adapter ther' is no ligth
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
May 23, 2011 | Dell Inspiron 2200 Notebook
Battery problem
its a battery problem try exchange it
please vote
Jul 25, 2009 | Dell Inspiron 2200 PC Notebook
Dell inspiron 2200 green LED battery Indicator flashing
sounds like your charging circuit isn't working or the adapter isn't putting out enough power or amprage to fully charge the battery, or you battery went bad. if the charging circuit is bad then so is *********** board, time to burry the system and buy a new one
Jun 21, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron Battery problem
Try this trick. Remove the battery from the laptop and make sure the ac adapter is not plugged in also. Hold the power button for 30 seconds. Place the battery back in and see if it powers on. If not let me know.
Hope this helps.
Oct 29, 2008 | Dell Inspiron 2200 Notebook
Can i run the laptop without a battery in it.plugged in with ac adaptor only
Yes, you can.
Laptops can run without battery with the AC, and it's fine, does not harm.
But however, I do not recommend you removing the battery and using the notebook with AC adapter only. The notebook is designed to be portable and with battery plugged in. In addition, using AC adapter only may cause the system to overheat since it is getting and using direct power from the power outlet.
Sometimes when you take out the battery your laptop doesn't work.
But that issue usually is related with some problem with the connectors of your motherboard.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 17, 2008 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Charger Malfunction
Try to turn off the computer and remove the battery from the bottom of the notebook. Turn on the computer with just the charger plugged in. If it doesnt turn on. you may have a bad power port.
If it has no power/charging issue since that happened except that the indicator light doesnt turn on when you plug in the charger, you may just need a bios update. Click here. That's the bios update for the inspiron 2200 from dell's website. You should have at least 30% charge on the battery and the ac adapter should be plugged in so you can run it. The computer will restart and will come back normally after this. I'd suggest that you backup your files before running this.
Sep 28, 2008 | Dell Inspiron 2200 PC Notebook
How to charge up my new battery
Let it charge for a good 12 hours before running the machine, basically overnight. The power management system will recognize that this is a new battery, and is programed to start the initial charge sequence for a new battery. It is supposed to do this whether the machine is in use or not, but I recommend 12 hours just to be on the safe side.
Aug 22, 2008 | Dell Inspiron 2200 Notebook
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
AC Adapter
Hey thats one of two things your (internal charging unit) if so your SCREWED if not its the sowtware issue witch means you gotta tweak the settings especially if you just upgraded your OS if tweaking doesnt work then re-install your OS then set your OS setting Correctly to the best of your knowledge have fun...it take a bit of patience and a couple hours i had the same prob.....seeya
Oct 28, 2007 | Dell Inspiron 2200 Notebook
Dell Inspiron 2200 Notebook Logo
186 people viewed this question
Alun Cox
