Question about Kenmore Elite 45986 Front Load Washer
The door pops open while drying the clothes
We have a kenmore elite smartheat quietpak9 dryer. While the dryer is on, the door will pop open slightly, just enough to turn the dryer off, but leave the light on. The clothes don't drop out. It happens with both large and small loads of laundry. What is causing this? I haven't seen this problem posted anywhere else.
  • 15,935 Answers
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
The dryer door always pops open stopping the dryer... how do I make it stay shut so the clothes will get dry without having to close the door every other minute?
Try putting less of a load in dryer. The weight of the clothes riding against the door, may be the reason why it pops open.
Apr 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite Smartheat quietpak9 model HE4, keep turn off after 15 to 20 minutes, it does getting hot. Could you please let me know what will be a problem. I bought it used so I am not sure how old is...
might need a clean out keeping heat inside of dryer,or you have abad motor,take the vent line off the back of dryer and run it to see if the block is in the vent line or in the dryer,also take off bottom panel,unplug dryer,take out lint filter and then remove the duct that the filter slides into,if it's blocked clean it out and you should be all set,usually the thermal fuse pops when this happens so that's why i say you could have a bad motor
Dec 15, 2009 | Kenmore Elite HE4 Electric Dryer
DRYER DOOR WILL NOT STAY CLOSED WHEN IN USE
Most likely the receptacle that the door latch goes into is broken. Go to local appliance parts dealer with model number and buy the $5 part, or order through Sears Parts Direct online.
Jun 13, 2009 | Kenmore Elite HE4 Electric Dryer
Gas dryer wont heat
You may have a blockage somewhere in your exhaust line. I had to have my professionally cleaned, but it fixed the problem.
Dec 11, 2008 | Dryers
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 - Smartheat Quietpak9
Dryer heats but will not dry clothes. Uncloged linted in screen and where the tube is. Did not fix the promblem. Could it be the heating element? And if so what is the cost to replace it?
Nov 15, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer won't start
Manual might be available on line type in your make and full model. Could well be the bulb that blew. Sounds like the door switch thou i see by other postings some times the filters can cause a similer problem
GUEST. 1. start switch is faulty...oops is it eletronic?it so disregard that. 2 drum is to tight 3 motor or switch on motor faulty
smitty123. Will drum turn by hand??? Can you hear the motor hum when you close the door???
Oct 27, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite 45986 Front Load Washer Logo
190 people viewed this question
Ron Lankford
Archaeology
Archaeology
reliableservice
