Question about Canon Cameras
Need a manuel on a copier on how to run it
I am looking for a free Emanuel down load on a canon copier 5070
    Problem Solver:
  • 17 Answers
Go to Canon's website, and look for SUPPORT. There you will find downloadable manuals for any Canon product. You can also download any software that came with the product.
Posted on Feb 10, 2009
Erorr 000602-0102 ir 5070
Turn power switch on right rear of machine off. Hold down the 1 and 9 keys while turning the power switch to the on position. There will be a cascading cursor run from the top of the screen to the bottom. May take a while to scan HDD. when it is finished turn off and then on again.
Jun 13, 2012 | Canon imageRUNNER 5570 Copier
CANON 5070 IMAGEWRITER POSTING "WASTE
To remove the recovery unit, open the upper right door & remove the developing unit. Be careful to unplug the toner sensor at the front frame. The plug will be damaged otherwise. From the front remove all the corona units. Slide out the fuser drawer. Remove the retainer screw & lock in the drum shaft. Slide out the imaging unit.
The recovery can now be removed.
Jan 20, 2011 | Canon imageRUNNER 5000 Copier
On our 5070 machine it ran out of staples. When
take out the staple cartridge and in the clear plastic you will see the arrow engraved the white box also has a arrow these two have to overlap each other to open the case it has two little tabs at the bottom press them in might wanna use a pen or something and the top part will pop up just pull it out
Feb 04, 2010 | Canon imageRUNNER 5570 Copier
Can't print or scan through USB port on Canon imageRUNNER 5070.
The port should be active. You can look for problems by right-clicking My Computer and then Properties. Under the Hardware tab, press the Device Manager button. Any hardware issues will show either a question mark or exclamation mark, disabled items with a red x. After the printer is connected, turn it on, then go to Start -> Control Panel. Here, go to add hardware. See if this finds it.
If not, have you added the printer after connecting it via USB under Start -> Printers and Faxes? What about inserting the installation CD before connecting the printer?
Apr 20, 2009 | Canon imageRUNNER 5000 Copier
Looking for photocopier user manual
Ok we Know this Model so are you looking for a User's Manuel or the Service Manuels And Yes we will accept paypal payments for this so yes we can help you with both User's Manuel and Service Manuals which one will you need.
User's Manuel is 45 dollars US
and Serivce Guide is 39 Dollars US.
this Service Guide is a Quicj reference to service Canon Copiers, we are not Aithorized to provide you any more stuff on this
Mar 05, 2009 | Canon Office Equipment & Supplies
Error code E000004-0010 on 3 5070 at the same time
First clear the error.
Press usermode star and release,press no2 and 8 at the time and release and press usermode star again and release,then you are in maintenance mode.
select copier,funcktion,clear,select error press ok,swiths the machine off at the main switch and on again.
That will release the errors
Jan 08, 2009 | Canon imageRUNNER 5000 Copier
Canon ImageRunner Scan feature won't connect to network
its waiting for the command from the computer. in order to use scan you have to down load the canon scan tool from imagerunner.com / support/ downloads/ office products/ then canon network utilities. look for network scan gear tool ... down load save open run setup then open the program and you can either let it search for a scanner or you can put in the IP adress for the copier. then under your scanning software ( ADOBE PRO) eg. you selesct the scan gear tool as the scanner. to scan a doc you put paper in feeder select scan online then from your computer tell your software to scan good luck
Jan 02, 2009 | Canon imageRUNNER 5000 Copier
Cameras Logo
49 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
