I need a side panel for a lian li AROMORSUIT PC-P60.
I have tried contacting lian li, however it appears as though they have no english customer services that i can see, i am looking for a clear side panel for the case.
If you could please either give me a UK contact number for lian li, or let me know where i can find this side panel (if it exists)
Thanks
    Sniper:
  • 86 Answers
After doing some research, I've narrowed it down to one panel, the W-65BT for the PC-P60 case. Now, this panel fits the PC-P60 case, and I've seen references that show that the PC-P60 and the PC-P60B (as shown in your link) may just be one and the same. The "B" suffix is probably just a color identifier. I did find this panel in two configurations at one of my favorite online dealers:
Lian Li W-65BT Transparent Side Panel
Lian Li W-65BM Transparent Side Panel
I hope this helps. After seeing this, I'd have to quote in agreement that this is "A gloriously bad-*** case".
Posted on Feb 11, 2009
Pc75-1. How do I flush hydraulic system?
Lian LI PC-75 work log. {56k beware} ' Overclockers Forums
www.overclockers.com/.../523704-Lian-LI-PC-75-work-log-56k-beware
Aug 18, 2007 - 13 posts - ‎9 authors I will be using the Lian Li PC-75 for the watercooling build. ... After about 1/2 hour with a jigsaw and dremel the finished product. ... Vapo sides for me so that they will be 4 inches longer and fit flush with the Lian Li PC-75 ... Will go higher now that I am runningcooler but for the purpose of the tests this works ...
Oct 14, 2015 | Cars & Trucks
Tip
How to create your own Run Command for any specific application?
Today tip will help you to make your own Run Command (program shortcut) to run a program or a document directly. No more need to navigate the location of a program or document to run it, simply click on Start button to open Run box and type the programs shortcut name to open it directly.
Follow the given steps to disable the save settings functionality for desktop:
To use this feature, you will need to be logged into your computer with administrative rights.
  • Click Start button and type regedit in Run option then press Enter for next.
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App paths
  • Now right click on App Paths and select New > Key, title the key and name it whatever you want your run command to be. In this case, we will try to create a run command for SecueCRT application.
  • New > Key > SecureCRT.exe
  • Now select the SecureCRT.exe folder and click right on (Default) string value then click Modify at the right hand side panel.
  • Here enter the path of the program that you want to execute in the value data field. In our case, the path of SecueCRT application will be C:\Program Files\VanDyke Software\SecureCRT \SecureCRT.exe.
  • Now again in right side panel, click right to create a new String value with the name SecureCRT and its values as C:\Program Files\VanDyke Software\SecureCRT\SecureCRT.exe
  • Now close the registry editor and restart your computer after any changes to go into effect.
on Jul 04, 2011 | Computers & Internet
Tip
Changing 80 mm Fans
Note that the stock "ADDA" fans are mounted with Lian Li plastic mounting hardware. (4 Clips.) If you remove them gently by pressing from the pins out and then pulling the pins out completely the mounts can be re-used for your new fans.
on Oct 15, 2008 | Lian Li Industrial Co. PC-65B ATX...
INALENE I need to make as many english words from these letters
inane, ale, lane, lean, line, nail, eel, ail,
hope I got some new ones for you
Apr 01, 2014 | Toys
Need a special Lian Li fan
Most computer stores will have one that will fit, although it may bot look the same. Take the old one with you to compare.
Mar 26, 2010 | Lian Li Industrial Co. PC-65B ATX...
Cabel of usb 2front too short cant connect o motherboard
check this out you would need the second cable on th list.
click here http://frontx.com/store/order_a.html hope that helps
Sep 25, 2009 | Lian Li Industrial Co. Lian Li PC-50 ATX...
P2015DN Left side of image cut off
If this is a HP LaserJet P2015dn Printer try the 24 hour # listed below.
I've spent countless hours trying to install solve printer problems by going on line but I eventually solve the problem when I break down and call the 24 HOUR NUMBER!
HP and Compaq products
800-HP invent
or
800-474-6836 24 hours a day, 7 days a week for most products U.S.: English and Spanish for most products
Be prepared to provide the following information: Serial Number (S/N), product name, model number
HP TouchSmart PC products
866-408-5408
24 hours a day, 7 days a week. U.S.: English and Spanish.
Compaq Presario PC products 800-OK Compaq
or
800-652-6672 24 hours a day, 7 days a week U.S.: English and Spanish. Customers using TTY 877-656-7058 6:00 a.m. - 3:00 p.m. PT
Mon. – Fri.
excluding holidays
Dec 15, 2008 | HP LaserJet P2015dn Printer
Hdd screws
just your local vendor they will help you
Jun 10, 2008 | Lian Li Industrial Co. PC-V300B ATX...
Computers & Internet Logo
132 people viewed this question
David Payne
David Payne
